Ariens 8hp Snowblower impeller shaft slack - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-12-2016, 04:22 PM Thread Starter
Ariens 8hp snowblower model 924050 has slop in the driveshaft from the impeller to the auger gear box.
The auger shaft seems ok no extra play in any direction.
Does this sound like the gear on the shaft and in the auger box is bad?
Everything does work just noisy.
Pulley for impeller and auger does appear to be all the way forward,but if you move the impeller it will move about 3/4 inch back and forth.
Thanks...............
hdman97 is offline
post #2 of 5 Old 11-13-2016, 12:24 PM
I think you need a flange bushing 05511200
Nr 9
Ariens 924048 Parts List and Diagram - (024501) : eReplacementParts.com
Stebekk is offline
post #3 of 5 Old 11-23-2016, 06:44 PM Thread Starter
Thanks Stebekk I'll check that too.
Got a round to tearing it down and the main bearing looks bad.
Have one on order.
hdman97 is offline
post #4 of 5 Old 12-20-2016, 06:20 PM Thread Starter
that seems to have fixed it
hdman97 is offline
post #5 of 5 Old 12-20-2016, 06:57 PM
Thanks (Given): 16
Likes (Received): 11
That would have been my guess. Glad the bearing change worked out.
My machine:
Stang is offline
