My experience - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-12-2016, 05:53 PM Thread Starter
My experience
Hi. I`m new in this forum. I just want to share my experience. Maybe it can help other people.
I discovered this forum because I had some trouble with my snowblower. I had inherited an Ariens 824 snowblower. I believe that at the time it was bought, it was an expensive snowblower. It had has some service done to it, but I don`t know what was fixed. Anyways. My problem with this snowblower was that it didn`t throw the snow very far. Maybe one meter at the most. Also, the snow was clogged very often. After googling a little, someone suggestet changing the throwing belt. And guess what. This actually worked for me. I found a video on youtube on how to change it. My brother and I used one hour, since none of us had done this before. The video didn`t suggest that you should be two persons doing the job. However...I had lesser experience in doing mechanical work before, but this was actually easy, if you have the proper tools. No expensive tools needed. This fix cost me around 50 $ (converted from Norwegian crowns). Parts are probably cheaper in the U.S. The throwing range is significant better now. Works as a whole new snowblower. Just want to share my experience. I`m probably not the first one having this problem. I also changed the oil. The oil plug is located on the back of the engine. A long bolt horizontal at the far back of the engine.
heinek1 is offline
post #2 of 7 Old 11-12-2016, 07:24 PM
Thanks (Given): 175
Likes (Given): 465
Likes (Received): 1044
And I am happy you blower is working better now
post #3 of 7 Old 11-12-2016, 08:30 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3357
Likes (Received): 679
Welcome to SBF heinek1. Thank you for sharing your experience with us.
post #4 of 7 Old 11-12-2016, 08:49 PM
Likes (Received): 483
Welcome aboard.....!
Thank you for sharing the info.
For better throwing distance you can also install an impeller kit on it (several members have done it with positive results).
post #5 of 7 Old 11-13-2016, 12:28 PM
Velkommen fra Norge
Stebekk is offline
post #6 of 7 Old 11-13-2016, 05:15 PM
Likes (Received): 1383
ALOHA from the paradise city.
post #7 of 7 Old 11-13-2016, 05:20 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 423
Likes (Received): 664
welcome to the forum !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
