Correct amount of gas - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-14-2016, 08:44 PM Thread Starter
The manual for my Ariens Platinum 24 SHO says to fill the gas tank to the red bar on the filler screen, but that is only a little over half full. Is this correct? I wouldn't be able to do the whole driveway with that.
rcleone is offline
post #2 of 5 Old 11-14-2016, 09:08 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
I took the strainer out of my gas tank. I have a GEN 3 LCT engine with a terribly designed gas cap (like a cheap radiator cap that is nearly impossible to line up). I leave about a 1/2" of room from the fill neck. I wouldn't worry too much about going above the red bar if you keep your strainer in. I believe there are 2 strainers in these engines anyway. The gas tanks on these engines are on the small side, especially on the 414cc motor. Additionally they should be made of plastic to reduce the risk of corrosion.
Cardo111 is offline
Thanks rcleone thanked for this post
post #3 of 5 Old 11-14-2016, 09:36 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Yup get rid of that useless and pain in the butt strainer. And fill the sucker up!
GoBlowSnow is offline
Likes bad69cat liked this post
post #4 of 5 Old 11-15-2016, 01:39 PM
Fill it up and go move some snow
Just don't over fill, I usually leave some room on top but not much.
I got rid of that strainer before i even finalized taking the delivery of my new blower.
Its a nightmare of a design.
linksbox is offline
post #5 of 5 Old 11-15-2016, 11:10 PM
After reading this thread, I'll remove my strainer as well. Anyone know why they're using such a poorly designed gas cap? It should be large, easy to remove & put back on while using gloves in the winter.
They're calling for up to a foot of snow in northern Minnesota this wknd. However we're only supposed to get up to an inch in my area unless the jet stream takes a dive on us. Let the games begin!!?
Erick is offline
