Trouble in NY! - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-01-2014, 09:02 PM Thread Starter
Trouble in NY!
I have a compact 22" and a storm heading my way,and I went out to the shed pulled her out , and guess what,it wont start! Just got it last year..so I need help!
scattergun2570 is offline
post #2 of 9 Old 01-01-2014, 09:48 PM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 184
Likes (Received): 931
When was the last time it ran?
Did you drain the gas over the summer?
If not, did you use fuel stabilizer over the summer?
Does it have a gas shut off valve? if so, are you sure its open?
Check the wire at the spark plug to make sure it's attached.
Do you have the choke "on" when trying to start?
those are some of the basics to start with..
run through those things, then let us know where things stand..
sscotsman is offline
post #3 of 9 Old 01-01-2014, 09:49 PM
Likes (Received): 11
How fresh is the gas? Last year? Last summer? Last month? If the gas isn't fresh, try draining the tank and carb, then refill with fresh from the pump!
HJames is offline
post #4 of 9 Old 01-01-2014, 11:35 PM
Likes (Received): 12
Agree with what has been posted, try pushing the carb drain to ensure its getting s proper amount a fuel.
rnaude241 is offline
post #5 of 9 Old 01-02-2014, 06:00 AM
Thanks (Given): 178
Likes (Given): 467
Likes (Received): 1047
After this check for spark. If it's getting spark it's pretty sure to be fuel related. Let us know what you find.
post #6 of 9 Old 01-02-2014, 08:14 AM
3 major things needed .spark ,compression, and fuel .more than likely its fuel related .on a stubborn small engine I will take the plug out an either replace it with s new or clean the old one an pour a fairly small amout of fresh fuel down the cylinder an replace the plug an give it a good pull.as long as I know the motor still has good compression .if the carb gummed up than definitely will need a good cleaning even just soaking the carb over night in kerosene can do the trick usually.
throttlejunkie450 is offline
post #7 of 9 Old 01-02-2014, 05:47 PM
You can try a little hot start spray... Often that will get things going enough to clear up a minor fuel issue. Fuel stabilizer is a must.
FairfieldCT is offline
post #8 of 9 Old 01-02-2014, 09:48 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Be happy to give you some help, just need you to come back and answer some of the questions
post #9 of 9 Old 01-04-2014, 07:00 AM
Likes (Received): 39
Sending out some bundles of rice crispy treats wouldn't hurt either.
nt40lanman is offline
