Ariens Deluxe 28 model 921022 differential - lubrication? - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 11-21-2016, 02:45 PM Thread Starter
Thanks (Received): 17
Likes (Received): 62
I have an Ariens Deluxe 28 model 921022. It has the squeeze handle which disengages the left drive wheel when it's squeezed, then re-engages it when released (for easier turning). The cable is connected to a differential.
My question: does the differential need lubrication and if so, what lubricant?
There is nothing in the owner's manual and I have found nothing with an online search. I lube the chain, gears and gearshift with white lithium grease. But the differential is pristine clean so didn't want to try lubing and create a problem.
Does anyone know for sure?
CO Snow is online now
post #2 of 3 Old 11-22-2016, 12:14 AM Thread Starter
No one knows?
post #3 of 3 Old 11-23-2016, 01:10 PM Thread Starter
Here's the response from Ariens:
"This area of the sno-thro does not need to be maintained yearly. If you wish to lubricate the shaft that the clutch dogs slide on you can with a 5W30 oil. This does not need to be done every year."
