Hydro Pro 32 transmission question - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 11-25-2016, 11:42 AM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Likes (Received): 33
My dad has a question regarding his fairly new Hydro Pro 32.
Our family used to have a 1967 Jacobsen 1200 SuperChief garden tractor which also had a Hydrogear transmission.
On that, you could change speeds 100% variable while moving. You could even stop the tractor using the transmission (neutral) and then go into reverse, all without touching the clutch.
The Ariens manual says to stop before changing gears.
Do you really have to stop with the hydrostatic transmission, or is it just like the 1960s Hydrogear where you could do whatever you wanted while moving? I do recall it said not to change too quickly, but a nice slow change seemed fine.
My dad is assuming this is either for safety, or just copied from manuals from friction disc machines but he doesn't want to damage the transmission either.
Thoughts?
1999 Ariens 924108 824SLE.
1933 GE Monitor Top refrigerator restoration video
ChrisJ is offline
post #2 of 4 Old 11-25-2016, 06:46 PM
Thanks (Given): 68
Thanks (Received): 30
Likes (Given): 147
Likes (Received): 99
You can adjust the leaver faster or slower at fast/slow as you like. No worries.
That must be copied from the friction disk models.
SAVAGE420 is online now
post #3 of 4 Old 11-25-2016, 11:14 PM
The manual comment was a mistake. You can shift the hydro on the fly. In fact, i just keep the drive lever down all the time and use the speed selector lever to control all movement/stops. Took a bit to get used to but the efficiency is amazing.
With that said, make shifts slow and smooth - there is no need to beat the crap out of the machine.
Noreaster is offline
post #4 of 4 Old 11-28-2016, 10:02 AM
Have the same machine, this is spot on.
What you may find however constantly holding down the drive lever gets a little old!
dbcooper is offline
