LinkBack | Thread Tools |
My Bob-Cat's the oldie, made by Wisconsin Marine, Lake Mills, WI, not the Bobcat skid steer folks. It's a 5 HP, 20" model.
The operating instructions say, "...remove engine plate and apply Lubriplate Marine A to chains in transmission. Add Lubriplate No. 2 to felt bearing feeders."
Hoping someone's familiar with these old workhorses and can tell me what/where the engine plate and bearing feeders are. Drawings/sketches/pics would be really helpful.
Thanks.
Thanks.
Sponsored Links | |||
Advertisement |
Welcome to the forum. Does your machine look like the one in this thread?
https://www.snowblowerforum.com/forum...p-5-speed.html
Similar, but not exactly. Mine has a B & S engine, not Tecumseh, and belt guard is orange like rest of machine, not black. I also have no headlight.
Originally Posted by marspatt
View Post
that engine is much newer than the snowblower..his likely originally had a Briggs as well..
If yours is a 2-speed forward and reverse, the insides look like this. The motor plate is the plate that the motor is bolted to, so no easy access. The felt bearing feeders can be seen in the dismantled photo. There are also oil cups on the outer ends of the shafts and the auger.
Here's a couple links to my ongoing rebuild.
Professional Power Equipment Technicians & Education Network (PPETEN) • View topic - Bob-Cat Snowblower Resurrection
https://www.snowblowerforum.com/forum...urrection.html
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes |
Thanks for the really helpful pics. I was afraid the motor plate was as you described, definitely not easy access. How important do you think it is to do this?
I assume the felt bearing feeders are the disc-shaped, felt-appearing items in your pic. Do they "feed" lube to the bearings?
Welcome from the Garden State
Yes, they hold oil and gradually "feed" it to the porous bronze iolite bushings.
The manual says;
"Every 100 hours or 4 years remove engine and engine mounting plate and apply Texaco All-Temp Grease or similar grade to chains in transmission. Saturate 3 felt bearing feeders (37) with motor oil (5W-30)."
The manual says;
Hey, Welcome! I have the exact same snow thrower as you do 5hp briggs and 20 inch cut.
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Posting Rules | |
