Craftsman 179cc - Snowblower Forum : Snow Blower Forums
Old 09-18-2017, 07:01 AM Thread Starter
Craftsman 179cc
I have a Craftsman snow thrower model 247.889550. The engine is a 179cc ohv doesn't say Tecumseh on it and if i'm right Craftsman is making their own engines which are probably China made. My first problem is it has low compression, but will start up. Do these engines have a bump in the cam that slightly opens the valve for easy start up? If so how do you do a compression test? The other problem is, I took off the head to inspect the cylinder and valves. The cylinder still has cross pattern on the cylinder walls, so I'm assuming the piston and rings are good. I took the valves off to clean, not much carbon on them. While removing the valves, I didn't notice the only one valve has a valve stem cap and only one valve has a valve seal. Which one goes where? Also If anyone knows the part number for a 179cc head gasket that has the yellow sealant printed on it, that would be great.
bluejeans is offline
Old 09-18-2017, 12:08 PM
Yes, almost all new engines have an exhaust valve bump built in to the cam shaft. The most you can get on them is about 60psi.
CRAFTSMAN SNOW THROWER Parts | Model 247889550 | Sears PartsDirect
Old 09-18-2017, 03:24 PM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 294
Likes (Given): 2962
Likes (Received): 545
Hello and welcome to SBF bluejeans. Below is a link to the MTD engine manual which I "THINK" is on you snow blower. Once you determine your engine numbers, found in the manual, finding a head gasket will be easier.
http://service.mtdproducts.com/Train...horizontal.pdf
Old 09-18-2017, 09:21 PM
Thanks (Received): 33
Likes (Given): 28
Likes (Received): 68
If only one valve had a seal and was designed that way my best guess is that it would go on the intake valve. The intake valve stem is subject to more vacuum and would be the likeliest point for excessive oil consumption. The stem cap I would guess is for the exhaust valve.
DriverRider is offline
Old 09-18-2017, 10:47 PM
its a honda gx160 clone made by powermore. a honda gx160 head gasket should work fine
Old 09-19-2017, 09:05 PM Thread Starter
Thank You guys, your answers are a big help.
