Briggs throttle plate always wide open - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 10-28-2017, 11:19 PM Thread Starter
Hey all,
So I have a craftsman 2 stage with a Briggs motor.
I've never run it before but it wouldn't start, cleaned the carb and it fired up 1st pull.
Problem when it fires up is that it over revs and it seems as though the throttle plate is wide open no matter what position the throttle selector is in.
I took it all apart and can see that the governor linkage from the carb to the throttle selector doesn't seem to ever close the throttle plate.
I can't see that there's anything missing or malfunctioning.
Any ideas?
dmm26 is offline
post #2 of 18 Old 10-29-2017, 02:15 AM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 167
Try using some PB Blaster or Fluid Film to loosen up the linkage and let it sit for a day after soaking it and then try it again.
The other issue may just be that you have a bad fuel line that will cause it to surge and or it has a lot of dirt in the fuel tank and fuel line and you need a fuel filter.
leonz is offline
post #3 of 18 Old 10-29-2017, 05:53 AM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
governor and it's proper linkage adjustment needs to be addressed . there are links in sections in here for shop information on how to properly adjust it,
example is if the spring is weak or in the wrong hole it will over rev. if the arm is not set to the governor by the book,it will over rev. that NO amount of lubricant will address wrongly done repairs,
10953 is offline
post #4 of 18 Old 10-29-2017, 10:39 AM Thread Starter
Thanks for the replies.
I'll try the PB Blaster and see. The guy I got it from said it ran fine last year but just wouldn't start now.
It doesn't appear that there has been anything done to the governor system, it's almost like the the linkage is working backwards if that makes sense.
I'll post a video of what i'm seeing and it'll be easier for everyone else.
dmm26 is offline
post #5 of 18 Old 10-29-2017, 11:04 AM
Jackmels's Avatar
Thanks (Given): 111
Thanks (Received): 168
Likes (Given): 373
Likes (Received): 705
The Butterfly itself may be Frozen. +1 on the PB Blaster to free things up.
Jackmels is online now
post #6 of 18 Old 10-29-2017, 11:08 AM Thread Starter
dmm26 is offline
post #7 of 18 Old 10-29-2017, 12:42 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 294
The throttle lever doesn’t have a direct effect on the throttle plate. With the engine off the throttle plate should be wide open. As rpms climb the governor will try to close the throttle plate. The speed control lever has a spring that resists the governors attemp to close the plate.
It looks like everything is hooked up properly. Does the throttle plate move freely? It’s possible that the governor arm is incorrectly position on the governor shaft. Do you have a tach to verify RPMs
drmerdp is offline
post #8 of 18 Old 10-29-2017, 12:55 PM Thread Starter
Throttle plate moves freely.
I don't have a tach.
I'll have to look at the arm then. It looks like everything is in place.
Thanks for the reply.
dmm26 is offline
post #9 of 18 Old 10-29-2017, 09:39 PM
tdipaul's Avatar
Thanks (Given): 74
Thanks (Received): 75
Likes (Given): 275
Likes (Received): 315
Guys who say this cannot be trusted. Anything is possible
1989 John Deere 1032
tdipaul is online now
post #10 of 18 Old 10-29-2017, 10:35 PM
Guest
Thanks (Given): 20
Likes (Given): 40
it ran last year,but not saying how well. used car saleman bs sales line, yet really sold because of problems .
op grab a shop manual and set the governor up ,
10953 is offline
