Finding Stator Acessory Power? - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-19-2017, 12:20 PM Thread Starter
Still new to this forum page and if there is a page that i have missed about installing led lights to my snowblower model number- 247.88355 please let me know. The issue im having is where to find stator power like some snowblowers have a wire hanging out for an accessory but alas ..mine does not. If this is not possible is getting a 9vlt battery my only other option?
Please help thank you
giantsfan1 is offline
post #2 of 7 Old 12-19-2017, 12:40 PM
Thanks (Given): 91
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 419
You have what engine, 212cc Tecumseh? Or Briggs? And no light? If you don't see a wire, you don't have electricity.
post #3 of 7 Old 12-19-2017, 12:49 PM Thread Starter
yes i have the Tecumseh engine. I figured with my luck this was not going to be easy , so there is no way to get a wire to the stator then? i will just have to use a small 9vlt battery?
post #4 of 7 Old 12-19-2017, 01:04 PM
Thanks (Given): 91
Likes (Given): 70
No wire coming out, no stator. You can find a used or blown engine and remove the stator from that. You can try eBay, Craigslist for a stator or engine, even on here, post a request. JackMels has many parts for sale. I'm not sure if there are different mounting patterns between engines or engine horsepowers. However you do realize you need to pull the flywheel?
post #5 of 7 Old 12-19-2017, 01:09 PM Thread Starter
thank you very much for your help in this matter.
post #6 of 7 Old 12-19-2017, 02:28 PM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 296
Likes (Given): 2987
Likes (Received): 550
Welcome to SBF giantsfan. Your snow blower appears to be a Tecumseh LH195SP-67514 (5 hp) and no stator is available for it. You could use a battery operated, handle bar mount LED bicycle light. I have the same motor in my single stage Toro and use a bicycle light clamped to the handle.
post #7 of 7 Old 12-19-2017, 03:03 PM
Thanks (Given): 91
Likes (Given): 70
It's a newer engine which I've never taken off the flywheel. Since there is no stator available it's possible there are no mounting holes behind the flywheel.
For the occasional evening clearing I do, I use a LED headset.
