Craftsman Drift Breaker 536.882702 5289 Restoration 10 hp 32" 2nd Generation - Page 18 - Snowblower Forum : Snow Blower Forums
post #171 of 184 Old 03-20-2019, 09:33 AM Thread Starter
sock-feet's Avatar
Likes (Given): 14
Likes (Received): 25
So how is it working for you ?? Do you notice much of a difference with the chute extension ??
I don't really see much of a difference, but it certainly looks badass. I can't believe how good this blower works and the HF engine is a great engine out of the box. I will recommend that you raise the high speed rpm on the linkage a bit higher than stock. It makes a big difference in power and throwing distance.
sock-feet is offline
post #172 of 184 Old 03-20-2019, 09:40 AM Thread Starter
sock-feet's Avatar
Likes (Given): 14
Originally Posted by Owenwalk View Post
Just found this thread, right as I was finishing up the instal of a 420 on a Drift Breaker. It was interesting to see how there were similarities and differences. The biggest one is that I raised the engine 1/2" to clear the oil caps as they interfered with the auger control on the right and the chute control on the left. Raising it up made it all fit beautifully. The only problem I now have is modding the cover to fit over the pulley.
Now here's the question. You added a battery to run lights, grips, power chute and starter. Did you install a generator to keep the battery charged? If not, how do you keep it charged? BTW, what do you do in the off season with the battery? I an thinking of seeing if the old Tecumseh generator will fit on the HF engine. Did you look into that?
Read newer posts. The Tech Generator is AC and wouldn't work to charge battery. The 420 is supposed to charge the battery if hooked up correctly from what I understand. I use a battery out of a honda jetski and use it for the ski in the summer and the blower in the winter. I have used the blower all winter without charging it at all. All of the added electrics work great. Turn the high speed throttle screw in to raise high speed RPM's. It makes a big difference.
post #173 of 184 Old 03-20-2019, 10:37 AM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4224
Likes (Received): 1643
to SBF Owenwalk
The HF engines are clones of Honda engines so I'm almost positive nothing from a Tecumseh is going to fit. Maybe the gas tank with a little modification
There are kits out there to add a charging coil to some of the HF engines but I thought the the big 420 had a charging circuit and came with 12 Volt electric start off the shelf?
https://www.harborfreight.com/13-hp-...arb-69736.html
Charging coils: https://www.bonanza.com/listings/Ign...RoCwmQQAvD_BwE
https://www.ebay.com/itm/Charging-Co...-/253293335872
post #174 of 184 Old 03-20-2019, 09:23 PM Thread Starter
sock-feet's Avatar
Likes (Given): 14
to SBF Owenwalk
Yea the 420 is supposed to charge battery out of box
post #175 of 184 Old 08-25-2019, 05:04 PM
Originally Posted by HCBPH View Post
I've restored a 536.882700 blower that was in really sad condition when I got it in the past. It's a sound structure, very well built machine but totally abused when I got it. I documented what I did to disassemble it and rebuild it, it was one really sad case when I bought it. In fact I bought it for the electric starter and planned to part it out, but decided to rebuild it instead. There was virtually no area in this blower or engine that I didn't touch, everything was in really sad (rusty or broken) state when I got it but it turned out well in the end. Even the engine was salvageable when I got done, and it's unbelievable how bad it looked when I initially got it.
The last digit of the model number apparently depends on whether the unit came with an electric starter or not when purchased from what I can tell.
I do have a doc on the machine as I went through it if you're interested in a copy along with a doc on what I do to get auger rakes that are rusted onto the auger shaft off. I have them both in pdf and doc format (the machine rebuild along with one on getting rusted auger rakes off). If interested, send me a pm with your email address and I can send you a copy of each of them if interested.
I have to admit getting the auger rakes off can be a problem. typically I use a combination of penetrant, heat and pressure to get them loose. I also made some special tools to help shock them and hopefully break the rust loose between the rakes and the shaft. One thing I do is once they're off, clean and paint the shaft then coat them with anti-seize to help reduce the chance of them rusting solid again (this model blower does have a full width auger shaft in it).
Where did you get the replacement stickers after you painted it?
R
wildernessjeep is offline
post #176 of 184 Old 09-01-2019, 10:49 AM
Likes (Received): 342
I didn't, I taped over the existing stickers when working on it and repainting. Sorry, never found a replacement sticker source.
HCBPH is offline
post #177 of 184 Old 11-25-2019, 11:06 PM Thread Starter
sock-feet's Avatar
Likes (Given): 14
Almost time to pull her out and get her ready to eat some snow.
post #178 of 184 Old 11-27-2019, 05:28 PM
I did this morning. Got 6"-10" of snow overnight and it was wet and heavy.
HCBPH is offline
post #179 of 184 Old 11-27-2019, 05:36 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 77
Likes (Given): 77
Likes (Received): 127
That is so weird I was going to ask you HCBPH if you still had you Craftsman Today? Don't you have a red II as well???
SimplicitySolid22 is offline
post #180 of 184 Old 11-27-2019, 08:22 PM Thread Starter
sock-feet's Avatar
Likes (Given): 14
How did she fling the snow? Looks like we might get some Sunday here in CT. Got it all lubed and ready for the fun. I need to put the some skids on this year for sure. It catches everything in driveway and jumps all over the place. I will address this and post. It has been a while.
