CraftsmanII 10/32 536.887000 Restoration Questions - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-27-2017, 03:28 PM Thread Starter
hey!
I picked up a free 536.887000 the other day that I knew was not running. It might be more work than it is worth. I picked it up with no idea what it was and figured it would be a 22-26" or so snowblower with a 5-6HP engine. I would swap out the engine with a Predator from HF and even if it only worked OK, it would be better than the shovel i currently own.
I am currently having a lot of difficulties finding info on this machine, so any links with info and a user manual would be awesome.
Turns out, the engine is missing the drive pulley. I am also thinking that maybe the engine i was given with this isn't even the original engine and if it has been replaced, it was replaced with an 8HP and not a 10?
So it seems like it is in good shape, but i can't determine if it is going to be worth it do do work on this machine.
If i were to attempt to do work on this machine, could i get by with a 6.5HP Predator from HF?
Also, i am not sure if it is even worth it for me to do work on this machine for my own use because my driveway is barely 2 cars wide and only 2 cars long. If there are cars in the driveway when it snows, I could probably clear my entire driveway in 2 passes. It is also wider than my front walkway to the street, which is just as short as my driveway.
ID:	120785   Click image for larger version
ID:	120793   Click image for larger version
ID:	120801   Click image for larger version
ID:	120809   Click image for larger version
ID:	120825   Click image for larger version
santims is offline
post #2 of 11 Old 12-27-2017, 03:49 PM
Thanks (Given): 57
Thanks (Received): 65
Likes (Given): 53
Likes (Received): 159
seems identical to mine, 10/28 , my threads about it are here https://www.snowblowerforum.com/forum...archid=6772169,
i have a manual if u need it, not the best scanned pdf though. seems alot of work/missing parts to get it going. fyi read my sig
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #3 of 11 Old 12-27-2017, 04:01 PM
deezlfan's Avatar
Likes (Received): 30
I have a Craftsman 10/32 and doubt a 6.5 predator would be adequate. The bucket can just pull in too much snow and the engine will probably be overwhelmed.
You would also need to find a two groove pulley to work in your situation. Buying the original style pulley may not work as the 10HP probably had a 1" shaft and the predator has a 3/4" shaft.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
post #4 of 11 Old 12-27-2017, 04:31 PM
deezlfan's Avatar
That Briggs engine you have in the photos looks sorta like it is a tapered shaft engine off a generator [It looks like the crankshaft is broken too.]
Did you get the chute, belt cover or missing auger support with the machine?
deezlfan is offline
post #5 of 11 Old 12-27-2017, 05:59 PM Thread Starter
I have the chute. No belt cover and no auger support.
santims is offline
post #6 of 11 Old 12-27-2017, 06:01 PM
Thanks (Given): 75
Thanks (Received): 181
Likes (Given): 65
Likes (Received): 625
I've seen 32 in Ariens with the 6.5 Predator do just fine...you might have to slow it down or take a smaller bite but it will work. As far as shaft size...just get a 3/4 to 1 inch adapter bushing and use the original pulleys.....
cranman is online now
post #7 of 11 Old 12-27-2017, 07:12 PM
Thanks (Given): 91
Thanks (Received): 180
Likes (Given): 70
Likes (Received): 413
As you can see from my signature, I have some big snowblowers including a 10/29. The "10" is the horsepower of the original motor. Yours had a 10hp. You really need a bare minimum of 9hp if not 10-12hp, but look at a minimum of 10.
I'd put it together.
JLawrence08648 is offline
post #8 of 11 Old 12-27-2017, 07:44 PM
deezlfan's Avatar
OP stated he does not have the original pulley/s.
deezlfan is offline
post #9 of 11 Old 12-27-2017, 07:54 PM
Thanks (Given): 75
Likes (Given): 65
simple to get pulleys at tractor supply to match any size he needs...with the 3/4 inch shaft as a bonus....I do this sometimes cause I don't have the bushing in stock...and I'm impatient.
post #10 of 11 Old 12-27-2017, 08:02 PM
Thanks (Given): 57
Likes (Given): 53
as i stated b4, i think this machine is too far gone for how much it needs for parts and $, theres lots out there that need less to get it going, imho
