Auger not turning - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 01-08-2018, 08:01 PM Thread Starter
Auger not turning
Hey everyone.
I received a hand me down craftsman snow thrower. Model 536886440
While trying to plow the driveway with this latest snowfall the front auger stopped spinning but the impeller still spins.
Shear bolts are still in tact
My guess is the worm gear on the shaft has worn out however I would like to ask you guys if you had any other guesses
Also if anyone knows of a video to replace shaft.
JKMich is offline
post #2 of 15 Old 01-08-2018, 08:06 PM
Thanks (Given): 58
Thanks (Received): 66
Likes (Given): 53
Likes (Received): 161
if shear pins are indeed intact then you are correct sir, gear in gear box broken/stripped, should be hearing some kind of harsh noise, normally not a cheap part or parts depending what it needs or how much destruction occurred
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #3 of 15 Old 01-08-2018, 08:09 PM
Thanks (Given): 91
Thanks (Received): 180
Likes (Given): 70
Likes (Received): 417
Is the impeller shaft turning? There's a roll pin that goes through the impeller and impeller shaft. If it is turning then it's in the gearbox. Sorry. However there is a woodruff key in the worm gear, they are very strong, doubt if it's that.
post #4 of 15 Old 01-08-2018, 08:13 PM Thread Starter
Originally Posted by JLawrence08648 View Post
Is the impeller shaft turning? There's a pin that goes through the impeller and impeller shaft. If it is turning then it's in the gearbox. Sorry.
Impeller still spins.
I am not hearing any noises when the shaft spins.
At this point it may not be worth fixing.
JKMich is offline
post #5 of 15 Old 01-08-2018, 08:14 PM
Thanks (Given): 58
Likes (Given): 53
take apart gear box to confirm, post some pics of her destruction
post #6 of 15 Old 01-08-2018, 08:57 PM
orangputeh's Avatar
Thanks (Given): 701
Likes (Given): 1183
Likes (Received): 1180
one good thing...
there are a lot of craftsman donor machines available for parts , cheap or free. especially in spring or summer.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #7 of 15 Old 01-08-2018, 09:03 PM
Thanks (Given): 91
Likes (Given): 70
$45 For the part.
post #8 of 15 Old 01-08-2018, 09:18 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 634
I bought an MTD 640F, its augers wouldn't spin. In my case I was lucky, and while the shear bolts were still in 1 piece (although bent), the woodruff key that aligns the worm gear to the shaft was, in fact, sheared off. $1 later, and I was back in business.
So I agree, it's worth opening up the auger gearbox to take a look. It might be something simple and cheap.
RedOctobyr is offline
post #9 of 15 Old 01-08-2018, 09:48 PM
Thanks (Given): 91
Likes (Given): 70
I mentioned it because it could happen. As we all know, sometimes you have to check everything. Start with the easiest or most likely and go from there.
post #10 of 15 Old 01-08-2018, 10:14 PM
oneacer's Avatar
Likes (Received): 245
I have seen the woodruff key shear as well, well worth opening up and checking out. Note, I have also seen rolled pins shear ... Just open it up and see what is going on instead of guessing ....
oneacer is online now
