Craftsman wheel removal mod # 247.88955 - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 01-09-2018, 02:12 AM Thread Starter
Hi guys. Quick question, I'm used to working on Ariens snowblowers but I now have this craftsman that maybe 10 years old. Need to remove the wheels, left wheel has a typical bolt that comes right out and the wheel comes off no problem. Right side no bolt. Anyone who is familiar with this model will know what I'm talking about and could tell me how to remove the other wheel but I'm going to try and post a pic on here. Thanks!
ID:	124242   Click image for larger version
mikeysb83 is offline
post #2 of 20 Old 01-09-2018, 04:49 AM
deezlfan's Avatar
Likes (Received): 30
Me thinks you have a broken bolt pictured there.
What's holding it together? Friction? Rust? Luck? Got me.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
post #3 of 20 Old 01-09-2018, 06:30 AM
I believe that style MTD machine used a bolt in that hole and then the wheel just slides on. It should pull off of there.
post #4 of 20 Old 01-09-2018, 07:44 AM
oneacer's Avatar
Thanks (Received): 86
Likes (Received): 259
oneacer is online now
post #5 of 20 Old 01-09-2018, 07:47 AM
oneacer's Avatar
That is an annual maintenance procedure on that machine, as I posted above. Looks like now you going to have to soak some Blaster in there and persuade it off, either by force or heat, then looks like the bolt broke off, requiring a drill and tap.
post #6 of 20 Old 01-09-2018, 10:00 AM
Thanks (Given): 91
Thanks (Received): 182
Likes (Given): 70
Likes (Received): 418
I agree with the others, a bolt goes through the middle. If you notice the axle and wheel has 2 flats so the wheel doesn't spin, the bolt just holds it so it doesn't slide off.
Four ways to get it off: bang it from the back, careful; apply heat, Oxy Acet is best, MAPP is ok; make a puller, either pulling from behind, recently there was postings on this, or drill 2 holes through the wheels, back it with a nut, and turn the bolt using the frame as the object the bolt will push against. You can use additional support by putting a backing plate against the frame.
Wheels should be pulled off periodically, axle sanded, then greased.
post #7 of 20 Old 01-09-2018, 10:52 AM
Likes (Received): 303
Jus
post #8 of 20 Old 01-09-2018, 11:06 AM
oneacer's Avatar
If your not mechanically inclined, just bring it to your local welder or machine shop, they'll have it off in no time at all.
LOL, actually, just run it ... the way it is rust welded on, you will probably be fine ... or , if it falls off, well there you go ... lol
post #9 of 20 Old 01-09-2018, 02:34 PM
Thanks (Given): 91
Likes (Given): 70
Another way is what jtclays said, you have the wheel off, remove any axle clips holding it, then either a roll pin or screw that holds the gear on, then slide the axle out with the tire on it. Easier working on it on your bench standing up. You can put a piece of wood behind the wheel and hit that to drive the wheel off. I hate banging axles as you'll peen it over, then you'll have filing to do.
post #10 of 20 Old 01-09-2018, 07:44 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 634
Agreed this would be a very good idea, and would help avoid these problems.
But at a minimum, for any machine, if you have the wheel off once, at least coat the axle with grease or anti-seize before reinstalling the wheel. And even if you don't need to take the wheels off for a specific purpose, doing it to lubricate the shafts, just once, could help avoid problems in the future. Doing this periodically is an even better idea, but even once would help you out.
For this situation, I like the idea of just running it for now. That assumes this is for your use, rather than prepping it for resale (where you have more of a timeline). If the wheel falls off, then it's taken care of the problem for you. And if it stays on, you can deal with it when the weather warms up, and it's less of a problem if you were to cause some sort of other issue while trying to remove it.
jtclays, I think an air hammer sounds like a handy tool to have available. Unfortunately, at my last visit, Harbor Freight was sold out of the $10 one I wanted to get:
https://www.harborfreight.com/air-im...kit-92037.html
But where do you get a flat nose/tip for it? The attachments that HF sells seem to be more chisels-oriented. I'm more interested in having something with a flat face, for trying to drive out shafts, etc. Rather than chiseling/cutting through things.
