Wrong size auger belt - Snowblower Forum : Snow Blower Forums
post #1 of 36 Old 01-09-2018, 08:23 PM Thread Starter
Wes Kootenay's Avatar
Working on a neighbor's Canadian Sears Craftsman 10HP/28" Model C950-52120-2. I believe this was made by Murray? We bought a genuine Murray auger belt # 585416MA, as this was listed on-line for this model. Tried to install it today but it is way too tight. Anybody know the correct belt # for this model?
Thanks.
Al
Wes Kootenay is offline
post #2 of 36 Old 01-09-2018, 08:30 PM
Thanks (Given): 485
Thanks (Received): 354
Likes (Received): 1178
ALOHA from the Paradise City.
post #3 of 36 Old 01-09-2018, 09:22 PM
Likes (Received): 35
Do you have the user manual ? I trust this more than any online vendor's wiki.
broo is offline
post #4 of 36 Old 01-09-2018, 10:56 PM
Thanks (Given): 89
Thanks (Received): 180
Likes (Given): 69
Likes (Received): 409
Measure the belt, it should be 38.2"
I have a Murray Craftsman 10/29 and a Murray Noma 9/27, both use the same belt 585416.
I only buy D&D Drive and Pix belts, Kevlar if they have them, because of the quality of their belts and the length accuracy.
There is an idler wheel adjustment, maybe you have that set too tight?
JLawrence08648 is offline
post #5 of 36 Old 01-10-2018, 12:09 AM
Likes (Received): 302
144
Likes JLawrence08648 liked this post
post #6 of 36 Old 01-10-2018, 12:23 AM
Thanks (Given): 56
Thanks (Received): 62
Likes (Given): 51
Likes (Received): 149
c950-52810-8 is my canadian craftsman 28/10 from the 80's..
traction belt
313851 1/2" x 39"
#51458 as listed in manual
carquest dayco ap37=39"od
auger belt
313847MA 1/2" x 40"
#51224 as listed in manual
carquest dayco ap38 =40"od
i used dayco from carquest @ ~$12 each
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #7 of 36 Old 01-10-2018, 09:05 PM Thread Starter
Thanks for the very helpful replies.
I have double checked that I have the correct belt, but for some reason it won't fit. I tried to refit the old belt (which was stretched so much that I had to move the idler to the max to make it work), same problem. It looks like, when I split the drive/auger sections to replace the belt something went out of whack and caused the distance from the engine drive shive to the auger drive to increase?? With the idler removed, I can force the belt on but, of course, the auger turns all the time.
This is my neighbor's machine, brought it to my place this evening so I can take a better look at it tomorrow.
Al
post #8 of 36 Old 01-11-2018, 08:16 PM Thread Starter
Hmmm, tried to post an update with pictures - didn't happen. Guess I'll have to introduce myself another six times to qualify?
post #9 of 36 Old 01-11-2018, 08:46 PM
So how's the weather up there?
Thanks Wes Kootenay thanked for this post
post #10 of 36 Old 01-12-2018, 11:44 AM Thread Starter
Ha, ha - thanks!
Our weather is VERY mild for the time of the year. Lots of wet, heavy snow. My Ariens loves it, my neighbor's Craftsman - not so much.
My wife was born in Detroit, she says "Hi".
Al.
