Auger belt keeps coming off 486.24837 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-11-2018, 09:50 PM Thread Starter
I have the correct belt, but it keeps coming off the idler pulley next to the auger pulley. I see no way to increase the tension
kayakpilot is offline
post #2 of 4 Old 01-11-2018, 10:17 PM
Thanks (Received): 100
Likes (Given): 101
Likes (Received): 242
It most likely is the idler pulley is work and on a slight angle when under tension causing the belt to ride off of it.
Dauntae is online now
post #3 of 4 Old 01-11-2018, 10:31 PM
Check all the bearings for every pulley for movement. Tip back the handle bars and check the front scoop part for movement from loose bolts or stress cracks. Check all the pivots for the idler for wear and looseness.
post #4 of 4 Old 01-11-2018, 11:36 PM
Likes (Received): 302
147
