Can I add an LED to my blower. - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-23-2014, 03:58 PM Thread Starter
I own an (16yr) old 5/23 Craftsman 536884810 although I did not come with a light I think similar models did. My safety switch is disassembled because it fell apart and I don't really need it but is it possible to get a wire from the engine that would run a low watt LED? I also know similar models had electric start but mine does not.
Thanks guy's.
nycredneck is offline
post #2 of 18 Old 01-23-2014, 04:01 PM
Likes (Given): 1891
Likes (Received): 669
if there is a stator on the motor yes if not you could add a rechargable light. the electric starter works off 110v from your house so there is no way to power a light off the starter circuit
post #3 of 18 Old 01-23-2014, 04:02 PM
Thanks (Received): 22
Likes (Received): 13
You'll have to check around the engine to see if there is a wire tucked (maybe under the gas tank? ) and test the voltage coming from it. Maybe call the manufacturer and ask what amperage is available from the stator assuming you find a wire for a headlight.
superedge88 is offline
post #4 of 18 Old 01-23-2014, 05:17 PM
Likes (Received): 18
The easiest and least expensive thing to do would be to buy a battery operated light. I personally have never used one, however, they seem to get pretty descent reviews. Here's a link to a pretty inexpensive one.
Sears.com
Smolenski7 is offline
post #5 of 18 Old 01-23-2014, 05:31 PM Thread Starter
Thanks for the replies fella's. I saw a guy on youtube who installed an 18v cordless drill battery and LED on his blower and it looked sweet. I am worried about vibration so LED might be the way to go, never even though about a simple battery bike light, that just may be the ticket. Thanks again!
post #6 of 18 Old 01-24-2014, 09:57 PM
Likes (Received): 10
In case you can't find what superedge88 suggests, I picked up a couple of -THESE- to use with my Path-Pro. They actually work pretty darn good and are amazingly comfortable.
JRHAWK9 is offline
post #7 of 18 Old 01-24-2014, 11:39 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
You would need to post the number of the engine itself. The blowers model number doesn't show a headlight or one as an option. If you can see where the electric start would mount usually there is a short one, two or three wire lead in that area if it has the ability to run a headlight.
Likes Steep&Deep liked this post
post #8 of 18 Old 02-09-2014, 02:40 PM
Likes (Given): 7
Can I replace the bulb (#1683) of the built-in factory headlight with a LED on my 2012 Craftsman Professional 30"?
Chuck2 is offline
post #9 of 18 Old 02-09-2014, 02:48 PM
Thanks (Given): 591
Likes (Given): 4374
You need to read this: https://www.snowblowerforum.com/forum...ed-lights.html
post #10 of 18 Old 02-09-2014, 03:09 PM
Likes (Given): 7
Thanks, Kiss4aFrog. I actually did read all of that last night & was still left unsure. I'm hoping to find an LED that will fit right into the socket for the original bulb. But I've been unable to find one for a 1683. If needed I should be able to reverse the polarity & I don't care if it flickers. As long as it doesn't cause me to have a seizure!
2012 Craftsman Professional 30" 357cc
Model # 247.888301
Heated Grips, Clarence's Impeller Kit
Chuck2 is offline
