Stalls when wet - Snowblower Forum : Snow Blower Forums
post #1 of 39 Old 01-24-2014, 10:15 AM Thread Starter
spacekowboy's Avatar
Stalls when wet
Hi, I've had this problem year after year and would love to solve it. My 8.5 B&S will start fine but once I start working and snow starts blowing back onto the engine, it will stall. I've made a few makeshift moisture shields, choke washer, replaced the gas cap without any success. I know this model has this problem from reading some other posts around the web. If there is no wind, and just a few inched to blow, it runs like a champ. Any help on this would be appreciated.
spacekowboy is offline
post #2 of 39 Old 01-24-2014, 10:19 AM
Blue Hill's Avatar
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Welcome to SBF! That must be so frustrating. Does it start right back up again after it quits? Does it sputter for a while before it quits, or does it just stop?
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 39 Old 01-24-2014, 10:37 AM Thread Starter
Sputters a bit - I can keep it going if I turn on choke. And it will start back up!
post #4 of 39 Old 01-24-2014, 02:04 PM
WestminsterFJR's Avatar
are you able to reproduce the problem by misting water (ex: with a spray bottle) towards the carb?
-Ken
2011 John Deere 1330se
WestminsterFJR is offline
post #5 of 39 Old 01-24-2014, 02:06 PM
Likes (Received): 42
If you can start back up with choke, you could be experiencing "carburetor icing." Moisture condenses and freezes in your carburetor throat. The "cold" condition requires a richer mixture to run effectively, thus the need for choke. You've got to keep the snow away from your carburetor with a baffle of some sort. Run her on a warm day with no snow and see if it still happens. That will eliminate weather as the cause. Good luck. MH
motorhead64 is offline
post #6 of 39 Old 01-24-2014, 03:07 PM
Likes (Received): 7
I've had this issue with two of my three blowers. I solved all of them by putting a cotton cloth in front of the intake for the cooling air opening around the recoil start. Hang it by four 3" copper wire, black as the engine. I put a hole in the cloth for the pull rope. I have not had this issue with my last B S engine. I'm forced to blow all my snow to the East, so when the wind is wrong I ice up my carb. Once I retired I just waited till the wind died.
You just give the cloth a good pull and the snow falls off so you resume ample air to cool your engine. Not hurt the engine yet.
This is a common problem in this area of high winds.
Mr Fixit is offline
post #7 of 39 Old 01-24-2014, 03:07 PM Thread Starter
I will try the water misting test. Even on a cold day if I start it up and let it run it idles fine. Also the muffler is very close to the carb
post #8 of 39 Old 01-24-2014, 03:57 PM
scipper77's Avatar
I have the briggs 8.5 as well and I have had problems as well. Here is a link to a thread that I am guessing you have already seen. Follow the link in post #15.
https://www.snowblowerforum.com/forum...ower-swap.html
scipper77 is offline
post #9 of 39 Old 01-24-2014, 05:26 PM
Following that thread into another showed one case where the problem was due to a faulty ground on the safety key. Moisture from the snow caused the safety key to ground out.
-Ken
post #10 of 39 Old 01-24-2014, 05:45 PM
scipper77's Avatar
If that thread showed me anything it is that the Briggs 8.5 is very problematic. I only wish I had a clear idea what the problems really are. Tell me what is wrong and I can fix it.
