Chute Control freezes - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-25-2014, 09:51 AM Thread Starter
Help - 26" craftsman Snow Thrower 2-way Joystick Chute Control freezes. I have to use a hair dryer to unfreeze. I have had this snow blower for 6 years and never have had this trouble. Has anyone else experienced this issue and what is the resolution? Thanks !!
Craftsman27 is offline
post #2 of 12 Old 01-25-2014, 10:21 AM
I had the same issue. I had a cable lubricating tool that was used for greasing cables on my dirtbikes and quads but it works for any cable. I greased the cable and never had a issue after.
just google cable lubricator and you will see what I am talking about if you do not understand. there only a few bucks and well worth it.
craftyman is offline
post #3 of 12 Old 01-25-2014, 10:49 AM Thread Starter
Thanks for the reply - my concern is there must be moisture in the cable as it keeps freezing up after I thaw with the hair dryer. I did use WD40 after I loosened it up last time but it refroze
post #4 of 12 Old 01-25-2014, 10:57 AM
thing is with WD40 is that it is water based. using the lubricating tool and a proper cable lubricant will push all the water out and lubricate the cable at the same time. you can usually get these at any atv/ dirtbike dealer for very cheap and is will worth it over the aggravation and frustration.
post #5 of 12 Old 01-25-2014, 05:10 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
I'm not arguing with your solution CM, but WD40 is sure not water based. WD stands for water displacement. It displaces water, but it evaporates fairly quickly. That's why it's not a long term lubricating solution, you have to keep re-applying it.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #6 of 12 Old 01-25-2014, 05:26 PM
That i did not know. I assumed it was cause i have never had any luck with using it in sub 0 temps.
post #7 of 12 Old 01-25-2014, 05:41 PM Thread Starter
I really appreciate all of the replies but I can't be the only one experiencing this type of problem (and still need a long term solution)
post #8 of 12 Old 01-25-2014, 05:41 PM
Likes (Given): 266
I'm not a huge fan of WD40. I think there are better choices out there for everything WD40 does.
Larry
post #9 of 12 Old 01-25-2014, 06:29 PM
Your not the only one. I said in my first reply that i HAD the same issue. But in doing the procedure i noted above i havent had an issue after.
post #10 of 12 Old 01-25-2014, 07:52 PM
I think it was posted where they put anti freeze in there cable so it wouldn't freeze. gaylanhd
BB Cub is offline
