inherited 60's craftsman - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-28-2018, 02:14 PM Thread Starter
My Mother in law bought this machine new- Model # C944.52950 8hp/26"
It worked fine other than a miss that drove me nuts, i decided to change the points & not knowing any better moved the internal mag. to clean it up. Then i found out you can't adjust the air gap unless you have a Tecuseum cutaway flywheel or the ability to set piston height with a meter. No one has a cutaway flywheel or is old enough to help me out around here, When i ask- If i took the motor off, bought the motor to you could you set the air gap- answer- Buy a new snowblower!
I thought why not just buy another Tecuesum 8hp motor? I;m told because the output shaft is a 1", nothing they have will fit!
Any help appreciated
royster is offline
post #2 of 13 Old 01-28-2018, 02:50 PM
Likes (Received): 22
If I'm reading this correctly, the output shaft on the original engine is 1" in diameter? If that's the case, any engine of similar or same size and a smaller shaft size can always have a shaft adapter to increase the diameter, or just use a different pulley.
FlamingSpaghetti is offline
post #3 of 13 Old 01-28-2018, 03:33 PM
scrappy's Avatar
Thanks (Received): 39
Likes (Given): 36
Likes (Received): 91
Tecumseh with points do not have a adjustment for air gap. Timing is adjustable. If the points are gapped to .020 you should be able to keep the timing the same or close to factory. Rotate the magneto and line up with the original marks of the hold down bolts. Not rocket science.
scrappy is offline
post #4 of 13 Old 01-28-2018, 03:52 PM
Sid
Thanks (Given): 10
Thanks (Received): 24
Likes (Given): 28
Likes (Received): 35
If there are no obvious impending disasters, Just go ahead and repair or replace the points with an electronic points replacement, its just a bolt on, and it will outlast the machine, Just be sure you get one with an anti backlash feature, [That hurts]. That machine is worth putting in a few bucks.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
Likes nwcove, Kiss4aFrog liked this post
post #5 of 13 Old 01-28-2018, 04:43 PM
Thanks (Given): 180
Thanks (Received): 164
Likes (Given): 1731
Likes (Received): 399
as scrappy said, you can try to line-up the bolt holes.
I've found however that if the points changed or are sanded/adjusted, the timing is no longer accurate (i'm a bit of a purist).
If you do swap out the standard points ignition (I wouldn't...i actually like points), you still need to set the spark advance.
the procedure is fairly simple if you have a dial gauge and a multimeter....it's super easy if you have the head removed
classiccat is online now
Likes scrappy liked this post
post #6 of 13 Old 01-28-2018, 05:15 PM
Thanks (Received): 157
Likes (Given): 378
Likes (Received): 603
Sid
https://www.bantasaw.com/catalog/browse.asp?i=199
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #7 of 13 Old 01-28-2018, 05:19 PM
scrappy's Avatar
Likes (Given): 36
Timing Tecumseh Engine
agree100%
It should at least make spark, enough to make it run. Fine tuning is the timing procedure.
Those electronic ignitions .... no way to time it. And how reliable are those made in china modules? Points work. Still will in 20 years.
scrappy is offline
post #8 of 13 Old 01-28-2018, 07:15 PM
If you look close you might be able to see the marks from the bolts you removed. Maybe you can try and line them up? Did you sand them all away?
post #9 of 13 Old 01-28-2018, 07:34 PM
Likes (Given): 378
dont be afraid to use one of those modules. i converted a few antique ( 1950's) 2 stroke outboard motors , which have been used in a salt water environment for many hours in the last 5 years , and there has been no issue with them that that ive been made aware of. they actually started easier, ran smoother than points timed with a dedicated timing fixture .
28 " Ariens Sno Tek
Toro CCR ss
Likes jsup liked this post
post #10 of 13 Old 01-28-2018, 10:54 PM Thread Starter
I did put new points on her, although there are marks on the shoulders of the 2 ears that hold the mag. in place, no corresponding marks to line them up with. I did try setting the air gap, put her back together, oh about 4-5 times & last time got a spark, but very weak, wouldn't start. I set piston to .80 BTDC on compression stroke using a .80 thick washer, that's how i got weak spark.
That's an idea, find a motor that will bolt on & if shaft size different, just use pulleys for that motor.
That's assuming pulley size doesn't mess to much with how she drives/blows, eh?
OR, i may have to buy that dial gauge & follow that procedure to set air gap up,
Thanks for tips
R
royster is offline
