no oil - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-01-2018, 11:39 AM Thread Starter
no oil
Why would my sera snowblower run out of oil after I had a tune upend oil change.
BriL is offline
post #2 of 16 Old 02-01-2018, 04:47 PM
Thanks (Given): 509
Thanks (Received): 679
Likes (Given): 3830
Likes (Received): 1472
to SBF BriL
Did your Sears snowblower lockup ?? If so how long after the service did it run before it locked up ??
How much oil was in it when you checked it ??
post #3 of 16 Old 02-01-2018, 04:52 PM
Thanks (Received): 11
Likes (Received): 17
Oil doesn't evaporate. I see only two options. Either the snow slower didn't actually have oil added as you believe or the oil leaked out. If it leaked you probably would have noticed the oil especially in the snow. Thus, my money's on the oil not being filled.
Tony P. is offline
post #4 of 16 Old 02-01-2018, 04:53 PM
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
Whoever did the service didn't re-fill the oil, and owes you.
jsup is offline
Likes 10953 liked this post
post #5 of 16 Old 02-01-2018, 04:54 PM
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 34
they probably forgot to add oil, ive seen it before
arienskids is online now
post #6 of 16 Old 02-01-2018, 05:00 PM
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
It's always a good practice to check if the oil level is up when and if you get it serviced by somebody else. They probably screwed up but now it's hard to prove... Is it still under warranty?
Dannoman is offline
post #7 of 16 Old 02-01-2018, 05:07 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 56
Likes (Received): 190
Originally Posted by BriL View Post
Why would my snowblower run out of oil after I had a tune up and oil change?
Because, that's why. As the others have said, maybe you got an oil drain, but not an oil change. Did you check the oil level before starting the machine?
Any oil caps missing or loose at the lower end of the crankcase?
What became of the engine without oil?
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #8 of 16 Old 02-01-2018, 05:23 PM
Thanks (Given): 21
Likes (Given): 254
That made me laugh.
jsup is offline
post #9 of 16 Old 02-02-2018, 05:57 AM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
Happened at a reputable service station here a few years back. Mechanic changed the oil on a newer model car...got sidetracked and forgot to replace the oil. Vehicle seized within a few miles. Law suit ensued and service station had to replace the engine with a new one. It does happen.
Prime is online now
post #10 of 16 Old 02-02-2018, 06:04 AM
Guest
Thanks (Given): 20
Thanks (Received): 53
Likes (Given): 40
Likes (Received): 94
how did the auto driver not see the OIL lamp blaring in their face ?
10953 is offline
