Snowblower moves, then stops - couple of jerks makes it move again - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 02-04-2018, 11:11 AM Thread Starter
So I got a nearly brand new snowblower of local classifieds, Craftsman C950-52126-0, 14.5 TP, 27" - Dual Stage. Guy basically sold it because it wasn't "running" and just fed up with it.
The unit looks new, I think it might have been used a handful of times by the condition of it. The issue the unit has it starts perfectly, put in in gear it moves forward/backward as supposed. Then randomly stops, jerking the unit a bit it moves again. It moves in every gear selected when it does want to move.
Now this unit from my research has one of these general transmissions which everyone says is junk and fairly expensive to replace ($300+). Now my understanding if these units fail the snowblower will not move at all, but my issue is not like that at all since the unit does actually move and in fact in every gear.
Any idea what could be causing this intermittent moving problem? I inspected the drive belt and it looks in great shape (like I said, unit was barely used).
Any help and input is greatly appreciated!
freebo86 is offline
post #2 of 22 Old 02-04-2018, 11:44 AM
Thanks (Received): 113
Likes (Given): 121
Likes (Received): 261
That model comes up as a 2011 Murrey made machine, Have not had to deal with the transmission so can't really help there but seems parts are available.
Dauntae is online now
post #3 of 22 Old 02-04-2018, 11:47 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 57
Likes (Given): 129
Likes (Received): 191
I guess you now know why it was for sale. Assuming it has cables for the auger and drive linkages, I would adjust the drive linkage at the base of the chassis.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #4 of 22 Old 02-04-2018, 11:47 AM Thread Starter
Thanks for the info, but i was able to found this sort of info also from;
https://www.partstree.com/parts/murr...on-h2-1733972/
But I am looking to see if i can find out what the issue might be, and avoid just replacing a transmission for nothing.
Oh i was totally aware of that it had a issue of sorts, but from the guys explanation it sounded like a drive belt issue or perhaps friction disc until I started looking deeper and found this doesn't even have that.
freebo86 is offline
post #5 of 22 Old 02-04-2018, 11:48 AM
Thanks (Received): 139
Likes (Given): 14
Likes (Received): 327
Not familiar with it, how about some pictures of the internals, might help.
HCBPH is offline
post #6 of 22 Old 02-04-2018, 12:31 PM
Wes Kootenay's Avatar
Possibly the drive gear shafts need greasing and are seizing a bit?
Just a thought.
Al
Name:	murray drive.jpg
Wes Kootenay is offline
post #7 of 22 Old 02-04-2018, 12:49 PM
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 129
Looks like a full transmission. Break out the tool box
Regards, Ted
post #8 of 22 Old 02-04-2018, 01:33 PM
Cardo111's Avatar
Thanks (Received): 125
Likes (Given): 79
Likes (Received): 168
Sorry to hear of the issue. Have you tried to contact GT Transmissions? I imagine it is out of warranty, this is the same company that manufactures Ariens Auto-Turn unit (DI300). Unfortunately you are likely looking at a full replacement and not a rebuild. You may have watched this already while doing your research but Donyboy as always sums it up pretty well. Beware of these they are also used on some Simplicity models as well.
Cardo111 is offline
post #9 of 22 Old 02-04-2018, 03:53 PM Thread Starter
Originally Posted by Cardo111 View Post
Sorry to hear of the issue. Have you tried to contact GT Transmissions? I imagine it is out of warranty, this is the same company that manufactures Ariens Auto-Turn unit (DI300). Unfortunately you are likely looking at a full replacement and nit a rebuild. You may have watched this already while doing your research but Donyboy as always sums it up pretty well. Beware of these they are also used on some Simplicity models as well.
https://youtu.be/8SWmQFtM8SY
Yes I saw that video as well, and thats why I was like well my issue isn't quite like that. According to the research I've done when the transmission fails the unit can't be shifted at all, it won't move at all.
Mine shifts no issues, and it moves - sometimes.
freebo86 is offline
post #10 of 22 Old 02-04-2018, 05:00 PM
Thanks (Received): 176
Likes (Given): 65
Likes (Received): 600
I have the General Transmission CVT on several Ariens lawn tractors in my junk pile. After just a hundred hours or less the fully plastic transmission craps the bed....and costs more to fix then the tractor cost new. I wouldn't want to own anything made with those plastic trannies.
cranman is online now
