Craftsman Shave Plate part # 790-00118-0721 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-13-2018, 10:51 PM Thread Starter
I have a Craftsman snowblower model 247.887910 The Shave Plate part number is 790-00118-0721. I've found many different Shave Plate part numbers beginning with 790-00118. but haven't found one with the last four digits of 0721. Would anyone know if any other part number beginning with 790-00118 will work? Also what do last 4 digits of the part number represent?
Thanks for any help !
guttersnipes199 is offline
Thanks CO Snow thanked for this post
post #2 of 11 Old 02-13-2018, 11:12 PM
Thanks (Received): 100
Likes (Given): 101
Likes (Received): 242
sears part direct says Substitution: 790-00118-4044 hear is a link to that
https://www.searspartsdirect.com/cra...7/1507200.html
and a link to a inexpensive scraper blade.
https://www.ebay.com/itm/Genuine-MTD...kAAOSwlY1ZI16G
Dauntae is online now
post #3 of 11 Old 02-13-2018, 11:16 PM
sock-feet's Avatar
Likes (Given): 14
Likes (Received): 23
This would probably work. It is for a 28" and at worse probable would be drilling new holes.
https://www.ebay.com/itm/28-Scraper-...IAAOSw8cNURzIl
sock-feet is offline
post #4 of 11 Old 02-14-2018, 06:07 AM
Thanks (Received): 137
Likes (Given): 14
Likes (Received): 319
You can also make your own, which I've done several times. Here's one I got some flat steel but the original had a lip on the back side. I picked up sound round stock that fit the dimensions of the lip and welded it onto the back of the scraper. Works for me.
ID:	132465   Click image for larger version
HCBPH is offline
post #5 of 11 Old 02-14-2018, 06:12 AM
sock-feet's Avatar
Likes (Given): 14
My brother is getting me a piece of 1/4" x 3" I may weld or bolt on the edge. I might grind the leading edge to sharpen it.
post #6 of 11 Old 02-14-2018, 08:26 AM
Likes (Received): 66
Won't that wind up costing you far more than the $22.75 that a new one would cost ?
https://www.partstree.com/parts/sear...790-00118-0721
Each to his own.
Vermont007 is offline
post #7 of 11 Old 02-14-2018, 08:36 AM
Likes (Given): 14
Each to his own.
I have a welder and cutoff saw, plus the scraper was discontinued for that 32" I put the picture out on. I buy cutoffs at my local steel distributor, I think that one I showed cost me about $3 plus my time to make it and a little welding wire. I've never sharpened a scraper bar I've made, the round edge on the steel I buy works just fine in snow for me including leftovers from the snowplows. Even if it's ice on the walks, a sharpened scraper doesn't chisel it off, or at least it hasn't for me.
Doing it yourself is also satisfying too.
HCBPH is offline
post #8 of 11 Old 02-14-2018, 08:53 AM
Let's all hope guttersnipes199 is similarly outfitted like you; but his 28" Shave Plate is NOT DISCONTINUED and is still available.
Thanks guttersnipes199 thanked for this post
Likes guttersnipes199 liked this post
post #9 of 11 Old 02-14-2018, 12:21 PM Thread Starter
Thank You Everyone for your help!
post #10 of 11 Old 02-14-2018, 02:40 PM
Thanks (Received): 14
Likes (Received): 52
Simply do a Google search using the part number. There are lots of options out there at a much lower cost than getting the part from Sears [~$56].
CO Snow is offline
