Electric starter kit issues Craftsman Snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-27-2014, 08:46 PM Thread Starter
Hello there, I have an 8HP Crafstman Model C950526787. About 25 years old. The started stopped engaging. Took it off and noted that there is a gear tooth with a black steel threaded device in it which fits over the started shaft.
I got a kit today, but the gear tooth with the threaded device will not thread onto the shaft.
Maybe I got the wrong kit? Although all the other parts are fine, including the gear.
Thanks!
barrington is offline
post #2 of 14 Old 01-27-2014, 08:52 PM
Are you sure the old one was bad? When they get old the gear sticks to the shaft and doesn't spin out anymore. Usually all it takes is a little penetrating oil to clean it up and some lithium grease or light oil to lube it up again.
post #3 of 14 Old 01-28-2014, 12:04 AM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
What model/serial numbers are on the engine
You got a kit, . . . . what was the part number for the kit ?? What was the starters part number on it's ID plate ??
Did you use the snow blowers model number to order the parts or the engines ?? If the engine has been changed that might be an issue.
Any photos of old and new parts ??
post #4 of 14 Old 02-23-2014, 05:49 PM
Thanks (Received): 48
Tecumseh engine right? Electric starter? There are two different starters and each uses a different helix. You'll need to either get the right one, or if the old plate is ok clean it up and reuse it, all the other parts are the same.
94EG8 is offline
post #5 of 14 Old 02-28-2014, 04:33 PM
I have one for sale if you need one that works.
awg1983 is offline
post #6 of 14 Old 02-28-2014, 05:26 PM
Thanks (Given): 590
Likes (Given): 4366
Well, he's been gone for a month so either he figured it out, sold it or just doesn't care if it has an electric start.
post #7 of 14 Old 02-28-2014, 08:14 PM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
That happens a lot on other forums, you wonder why they even bothered to ask, huh?
You post something you should come back and at least say something, anything, at least one time?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #8 of 14 Old 02-28-2014, 09:05 PM
Yea, proper etiquette would be to come back and close out the thread somehow when you came to some type of conclusion. Perhaps he is just waiting for warmer weather to fix this?
post #9 of 14 Old 02-28-2014, 10:24 PM
Thanks (Given): 590
Likes (Given): 4366
It's not a big thing it's just nice to have some closure because it's more helpful for the next guy doing a search. With this one we're not even sure what his problem was in the first place, wrong kit or he just didn't understand how it went on ?? I hate when you've gone a couple pages, done research for someone else, posted exploded drawings and then all of a sudden . . . nothing ??
"Did that old cannibals charge finally catch up with them?"
post #10 of 14 Old 03-01-2014, 01:54 PM
Who knows, I definitely understand the value in finishing a thread and posting your results or methods of repair. This forum has been invaluable to me in regards to my snow blower! I am excited...we are on tap to get 6-10" of snow tonight! Get to put the little mighty mouse predator to the test!
awg1983 is offline
