What model is this unit? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 09-03-2018, 09:03 AM Thread Starter
Hello all, this is my second post. My first post led to the revival of the machine and this post hopefully will lead to the long lasting life of my machine. I can't figure out what model number my machine is. I need this info to try and find parts...specifically a track tension adjuster for the right side (left is pictured below). Also to figure out where the oil drain is. If anyone can help please leave your 2 cents. Much appreciated.
ID:	146521   Click image for larger version
ID:	146523   Click image for larger version
ID:	146525   Click image for larger version
ID:	146527   Click image for larger version
ID:	146531   Click image for larger version
ID:	146533   Click image for larger version
Ercove21 is offline
post #2 of 4 Old 09-03-2018, 09:50 AM
orangputeh's Avatar
Thanks (Given): 625
Thanks (Received): 152
Likes (Given): 912
Likes (Received): 972
correct me if i am wrong but i think the oil drain is in the first pic of the second row. that square headed bolt.
not familiar with these blowers but once you find out I'm sure you can find a free or cheap donor machine on craigslist for parts.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #3 of 4 Old 09-03-2018, 10:29 AM
sock-feet's Avatar
Likes (Given): 14
Likes (Received): 23
Take the entire track assy and disassemble it and lube it. You will find that some of the axels are rusty and seized inside the plastic wheels.
sock-feet is offline
post #4 of 4 Old 09-03-2018, 12:04 PM
Grunt's Avatar
Thanks (Given): 236
Thanks (Received): 274
Likes (Given): 2765
Likes (Received): 500
I found this manual and it may be close enough to help with parts and maintenance-
Sears model 536.884811 5/23 Trac Blower-
https://drive.google.com/drive/folders/0B0J8tVzfnr5VcHpYLU9oSFpfSkk
Your Sears 143.975001 motor is actually a Tecumseh HSSK50-67338R for ordering parts.
Tecumseh Service Manual-http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
To bad you didn't copy the model number before drilling through the sticker.
Toro 421-QZE (38585) 2008
