Craftsman 27” 8.5HP (536.881851) Impleller Mod - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 11-11-2018, 07:45 PM Thread Starter
Wxm
Per recommendation of the member on this forum, I decided to give the impeller mod a try. The impeller of the blower is more than 1/8" thick. I would be a bit of challenge to drill through that. Fortunately, each of the blade has a 1/2” pre-drill hole. I am not sure what the holes were originally for, and decided to "borrow" them for the rubber mount.
ID:	148371   Click image for larger version
ID:	148373   Click image for larger version
ID:	148377   Click image for larger version
ID:	148379   Click image for larger version
Wxm is offline
post #2 of 18 Old 11-12-2018, 11:36 AM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 560
Likes (Received): 254
Wow, you got right to work! Nicely done.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #3 of 18 Old 11-13-2018, 01:23 PM
I have the same Craftsman machine, with the same 1/2" hole that goes through the impeller blade, as well as a backing "U" shaped stiffening gusset that is welded to the impeller blade. Both the impeller blade and attached gusset are about 1/8" thick. That is probably why you used the 1 existing drilled hole in each blade, since you would need to driil through approx 1/4" of combined thickness if you wanted to add a 2nd or 3rd hole to better support the rubber strip. This is precisely why I have held off doing the impeller mod on my machine. Do you think 1 bolt and washer will adequately hold the rubber strip to prevent it rotating away from housing? I would be really interested on your feedback when you use this mod in snow. If it is successfull, I will do the same on my machine. Hope it works - sure would be convenient not to need to drill more holes through 1/4" with very limited room.
cargy2003 is offline
post #4 of 18 Old 11-13-2018, 06:38 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 28
Likes (Received): 39
To drill the 1/4" holes in the blades, start with a 1/8" drill, it will be a lot easier. Also unless you are sure that your drill bits are sharp, use new ones. Piece of cake.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is online now
Likes Wxm liked this post
post #5 of 18 Old 11-13-2018, 08:31 PM
SkunkyLawnmowers's Avatar
Location: Brit girl from London now in the Blue Ridge Mountains
Thanks (Given): 29
Thanks (Received): 26
Likes (Given): 58
Likes (Received): 99
I was faced with a similar problem, the supporting bar running underneath of the impeller. I decided to take my impeller off and drill on the bench, which made things so much easier and more precise.
Here's how I did mine -
https://www.snowblowerforum.com/foru...ification.html
'Parker' Honda 2017 HSS724AWD
'Puffer' 2011 Toro 1 Stage
'Jen' Honda EM6500 generator
'Tilly' Honda Mantis tiller
Remember the 7 Ps - Proper Planning Preparation Prevents P Poor Performance
SkunkyLawnmowers is online now
post #6 of 18 Old 11-16-2018, 10:40 PM Thread Starter
Wxm
I used M12x25mm stainless steel bolt with a lock nut on the back, use a fender oversized washer to hold the rubber in place, I also placed a lock washer between the bolt head and the washer. I also got the relatively harder rubber, giveing the sidewall on one size, the a little lip on the other side of the impeller mounting surface, the rubber sits pretty snug. I am pretty sure I am good. Canít wait to try it in real application. Will report back.
Just received the little 90 degree shut-off valve. Will try to add the shut off valve in the fuel line tomorrow.
Wxm is offline
post #7 of 18 Old 11-16-2018, 10:46 PM Thread Starter
Wxm
If I have to drill it, I probably would take it off too. It would dfinitely be much easier to do it on a drill presss.
Wxm is offline
post #8 of 18 Old 11-16-2018, 10:50 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 73
Likes (Received): 435
Use one hole with a torque but using flat bar stock to keep the rubber flat.
post #9 of 18 Old 11-17-2018, 09:34 AM
As noted above, I have the same blower and wondered if 1 bolt would be adequate to attach the rubber. I decided to try it since we were going to have snow yesterday. I did it differently than OP though, Instead of a fender washer, I used a predrilled flat bar, to more evenly distribute the clamping force of the one central bolt, along the length of the rubber strip. The rubber strips I used were 3/16" thick. The pre-existing hole in the impeller vane is 7/16" dia, so I used a 3/8" coarse thread bolt and nut, with a NordLock washer under each nut to ensure it remains tight.
We had about 4" of wet snow yesterday. The blower easily cleared it with no issues, though I am not sure there was a significant difference in performance compared to without the rubber - maybe I should have used thicker rubber than 3/16"? However, the 3/16" rubber seems quite rigid and does not bend easily.
The flat bar properly held the rubber strip in place, using only the 1 central bolt, so this seems to be a success. If you have a similar Craftsman 536.881851 this sure simplifies installing the impeller mod.
ID:	148621   Click image for larger version
ID:	148623   Click image for larger version
ID:	148625   Click image for larger version
post #10 of 18 Old 11-17-2018, 09:48 AM
Thanks (Given): 29
Likes (Given): 58
Originally Posted by cargy2003 View Post
...However, the 3/16" rubber seems quite rigid and does not bend easily.
Hi,
I had your issue on my Honda, the rubber was too rigid. I experimented with various types of rubber material before I settled on using baler belting from Tractor Supply. It's firm enough to scrape the impeller housing of snow and ice but flexible enough that it will bend slightly at the impeller end to help clean the housing. Pic below from my mod
Name:	7. belting bending.jpg
