247.88255 Transmission Replace? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-01-2018, 10:34 AM Thread Starter
WRS
I may need to put a new transmission in my Craftsman 247.88255. It's got new belts and the cable tension looks OK. Anything else it might be?
Thanks!
Bill
WRS is offline
post #2 of 5 Old 12-01-2018, 01:14 PM
Thanks (Received): 14
Likes (Received): 52
What seems to be the problem?
CO Snow is offline
post #3 of 5 Old 12-01-2018, 01:51 PM
GAR
GAR's Avatar
Thanks (Given): 63
Thanks (Received): 18
Likes (Given): 245
Likes (Received): 147
Its fairly easy to replace, the hard part is coughing up the $$$ for the part....I have replaced a few of them and best price I can find is on EBay for $130 W/free shipping. I pasted the link to it...Good luck.
https://www.ebay.com/itm/OEM-MTD-918...YAAOSwEzxYd4~E
"When I no longer thrill to the first snow i'll know i've grown old"
GAR is offline
post #4 of 5 Old 12-01-2018, 06:09 PM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 403
If it doesn't move and the belt is tight, it's the transmission. You can turn the pulley and if the axle does not turn, it's the transmission. Real easy job to replace, about 30 minutes.
JLawrence08648 is offline
post #5 of 5 Old 12-01-2018, 06:14 PM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
most be weak? he already sold 139 of them
132619 is offline
post #6 of 5 Old 12-02-2018, 08:44 AM
Thanks (Received): 136
Likes (Given): 14
Likes (Received): 318
This is another of those "better idea" that aren't IMO. They used to use a Tecumseh gear transmission in years past and thing was built like a tank. Don't know about these new plastic case units.
HCBPH is online now
