247.88355.00 worth it to repair? - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 12-03-2018, 12:00 PM Thread Starter
Hi All,
have a broken friction wheel and a gouged disk/plate (the one hitting the friction wheel)
is it worth it to have it repaired. not sure if i can tackle it myself so a home repair person will be called....
thanks
ultrnoob is offline
post #2 of 13 Old 12-03-2018, 12:41 PM
Thanks (Given): 75
Thanks (Received): 181
Likes (Given): 65
Likes (Received): 625
How old is the machine and it's condition? Most repair shops won't use old parts and get anywhere from $60 -$100 dollars and hour. Could be pricey if you don't do the work yourself.
cranman is online now
post #3 of 13 Old 12-03-2018, 12:54 PM
Thanks (Given): 91
Thanks (Received): 180
Likes (Given): 70
Likes (Received): 413
The gouged disk may not be a problem. Post a picture and you'll get accurate feedback.
Replacing a friction disk is a scary daunting task but easy! Don't be scared unless you are a clutz with tools. It's greasy but easy. There are YouTube videos, Check out DonyBoy.
JLawrence08648 is offline
post #4 of 13 Old 12-03-2018, 01:18 PM Thread Starter
Thanks both.
JLawrence, the gouged plate needs to be replaced. if I leave it as is it's going to rip out the rubber on the friction wheel every time I use it. Best way to describe it is the rubber on the friction wheel came loose without me knowing and it kept rubbing against it.
I can replace the friction wheel myself. saw Donyboy's and others' video as well.
a sample pic link is attached. It's the plate below the friction wheel. imagine it gouged in a swirl pattern..
https://www.searspartsdirect.com/rep...6455578067.jpg
ultrnoob is offline
post #5 of 13 Old 12-03-2018, 01:22 PM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 296
Likes (Given): 2974
Likes (Received): 550
Welcome to SBF ultrnoob. Looking at the parts list, it will cost you a minimum of $80 just for parts, although checking other parts suppliers may show cheaper prices. Having a shop do the repairs would probably be around $200?????
post #6 of 13 Old 12-03-2018, 01:24 PM Thread Starter
Thanks Grunt.
ultrnoob is offline
post #7 of 13 Old 12-03-2018, 01:44 PM
Grunt's Avatar
Thanks (Given): 250
Likes (Given): 2974
The 247 in your model number indicates the machine was made by MTD. As suggested, youtube has many videos on how to do the repairs yourself and save some money. Here is the parts list for your machine.
https://www.searspartsdirect.com/mod...7/1507200.html
post #8 of 13 Old 12-03-2018, 03:41 PM Thread Starter
thanks again Grunt...can you pls confirm the Disc Assembly part is no. 656-04025A?
ultrnoob is offline
post #9 of 13 Old 12-03-2018, 05:57 PM
Grunt's Avatar
Thanks (Given): 250
Likes (Given): 2974
Yes, the friction disc (metal plate) is 656-04025A. The friction wheel assembly is 684-04153C and the friction wheel rubber only is 935-04054.
post #10 of 13 Old 12-03-2018, 06:41 PM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3908
Likes (Received): 1500
It's not that hard to do. I did what looks to be the exact problem on my Troy/MTD and having a chewed up disc from the PO is why I ended up with it free.
It's not easy but without disassembly you can swap out that chewed drive plate. The smaller your hands are the better. Mine aren't that small and it was a pain getting back behind it.
I had a really hard time figuring out how that drive wheel was going to come out until I got the new part. Once you have the replacement part it's pretty self explanatory how you're going to get the old one out and the new in. I wasn't using any special tools and I did it out in the cold to boot (no space in the garage). There is just enough room to get a wrench back there for the 5/8" nut and pliers or vicegrip to gently hold the threaded stud.
Name:	102913 damaged friction plate 2.jpg
Likes Grunt liked this post
