carb leaking after cleaning - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-15-2018, 05:49 PM Thread Starter
I have a Craftsman snowblower with a 6.0 hp Briggs & Stratton. I cleaned carburator and put back on. It started right up and ran but after shutting it off, it started leaking gas out of the little ports of the carburator. What causes this? Thanks!!
aswpaugh is offline
post #2 of 6 Old 12-15-2018, 06:44 PM
Sid
Thanks (Given): 10
Thanks (Received): 24
Likes (Given): 28
Likes (Received): 35
The carb needs a good looking at, sounds like the float valve seems not to be closing as it should. All the jets and openings should be cleaned.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #3 of 6 Old 12-15-2018, 08:48 PM
Thanks (Given): 75
Thanks (Received): 181
Likes (Given): 65
Likes (Received): 626
put a fuel shutoff on every machine,.,.
cranman is offline
Likes Kiss4aFrog, JamesReady liked this post
post #4 of 6 Old 12-15-2018, 08:56 PM
Thanks (Given): 91
Thanks (Received): 180
Likes (Given): 70
Likes (Received): 413
Agree with Sid, float inlet valve is not closing or sealing.
post #5 of 6 Old 12-16-2018, 01:58 AM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3908
Likes (Received): 1501
to SBF aswpaugh
Sounds like it's leaking from too much fuel. If the float is set too high the fuel level will be too high and it will leak. If the needle wasn't attached to the float properly it might not be able to seat allowing too much fuel into the bowl and it will leak or the needle and or seat might be defective or damaged and not sealing which will also let in too much fuel and it'll leak.
post #6 of 6 Old 12-16-2018, 07:42 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
did you by chance loose the tiny rubber needle valve seat inside the hole the needle goes into? without it , they will leak from overflowing
132619 is offline
