Help! 536. 918200 gear box - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-17-2019, 12:20 PM Thread Starter
I just acquired a 22” craftsman that used to be my grandpas. The impeller was moving back and forth inside the gear box so I took it apart and found some shavings in there. I found a diagram of the gear box and it seems that I’m missing a part, a part they no longer sell. The part I need is number 45 on the auger diagram and the part # is 50823. https://www.searspartsdirect.com/model-number/536918200/0247/1507000.html
Does anyone know of a part that I could use to make it work?
Modea2006 is offline
post #2 of 7 Old 01-17-2019, 01:10 PM
Likes (Received): 29
You may be able to find out how many different machines used that gearbox by a part # web search. Then surf ebay or CL for donor or individual bits.
guzzijohn is offline
post #3 of 7 Old 01-17-2019, 07:07 PM
Likes (Received): 20
Looks like the missing part is a thrust washer. You can probably find a generic one online once you figure out the dimensions you need. The old machines usually had a few shims in there also to take out any play. If you cant locate one in a few days, send me a PM and I'll dig one out for you.
Have fun, Sidegrinder.
sidegrinder is offline
post #4 of 7 Old 01-17-2019, 09:06 PM Thread Starter
I ended up using some machine bushings, I got a few of them and then stuck an o ring in between to help get the right width. I noticed a little bit of wear where it looked like it had rubbed for a while but it didn’t look too bad. So hopefully it will all last long enough until I can find me an auger assembly to replace it all.
post #5 of 7 Old 01-17-2019, 09:31 PM
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 59
Likes (Given): 56
Likes (Received): 90
SimplicitySolid22 is offline
post #6 of 7 Old 01-17-2019, 10:00 PM Thread Starter
Yup that’s exactly what it looks like
post #7 of 7 Old 01-18-2019, 11:33 AM
Thanks (Received): 137
Likes (Given): 14
Likes (Received): 319
Check McMaster Carr, think I got the ones I needed from there or from Fleet Farm in the past. Sorry, can't remember which.
HCBPH is offline
