Tecumseh engine ID - Snowblower Forum : Snow Blower Forums
Old 01-26-2019, 11:23 PM Thread Starter
Tecumseh engine ID
Hi Guys,
I just acquired an older Craftsman II 826 tracker with a Tecumseh 8 hp engine. I need to do some maintenance on the engine but cannot find engine plate anywhere to figure out the model. Online search says to look under the cover on top, but there is no cover on top, at least not a shroud type cover. Any ideas where to find the model number? Also, any idea how old the machine is?
Blower: model #768884900
Age: ??
Color: silver
Features: reverse, electric start
Engine: Tecumseh 8 hp Snow King
I would appreciate any input you have on this machine! I just can’t seem to get very far on general internet searching.
greyinggrayling is offline
Old 01-26-2019, 11:41 PM
SimplicitySolid22's Avatar
Thanks (Given): 56
Thanks (Received): 74
Likes (Received): 110
Do you have an Elec. Starter? If so where the starter plug/Button on top of engine shroud.....You need to remove two screws holding that on and it is underneath that.
SimplicitySolid22 is online now
Old 01-26-2019, 11:45 PM
Thanks (Given): 56
Old 01-26-2019, 11:59 PM
Thanks (Given): 56
Not sure how but I found a wheeled one for sale and it was 2009!
2009 CRAFTSMAN 768.884900 For Sale In Dyersville, Iowa
Not sure if that is possible. Figure Mod number would be different.
Old 01-27-2019, 12:01 AM
Thanks (Given): 56
Old 01-27-2019, 12:16 AM Thread Starter
Thank out for the info. I’ll take off that plate on the top in the morning and chase it from there.
I’m figuring this machine is out of the 1990’s or early 00’s if I had to guess. Some rust, surface only.
I need to replace the carb bowl, has a pinhole leak. For the price of the bowl and shipping to AK, I figure I’d go ahead and replace the whole carb. There was quite a bit or orange debris in the bottom of the bowl, so likely gunked up in the internals.
Old 01-27-2019, 12:32 AM
Thanks (Given): 56
It is not a plate it is the elec. starter cord plug on top of shroud should be black plastic with plug(male/Two prongs) and red button on top. Remove the two bolts attaching that plug on top of metal shroud and number should be under black plastic plug.
Carbs are cheap on ebay.
Your engine will most likely be a Tecumseh HM-80 or an HMSK80.
Sometimes there is a sticker if your face is in front of Pull cord in front of engine there is a sticker on bottom left of engine tucked just below carb cover/heater box
on left side of shroud down there.
Old 01-27-2019, 04:57 PM Thread Starter
Thank you Simplicity for your info.
Found the engine info under the push start assembly just as you described.
143 766152
My understanding is 143 indicates Craftsman, rest is the actual Tecumseh engine 766153
Now I can order parts online with a little more comfort.
Any idea the age of this blower? Does the silver color narrow it down to a certain decade?
Old 01-27-2019, 05:13 PM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 294
Likes (Given): 2962
Likes (Received): 545
Welcome to SBF. Your actual Tecumseh engine model number is HM80-155321L. This is the number you would use when ordering parts for the engine. The info is at the bottom of the service manual.
Thanks greyinggrayling thanked for this post
Likes greyinggrayling liked this post
Old 01-27-2019, 05:25 PM
Thanks (Given): 56
Grunt is correct HM80-155321L.
Back of manual XII Right hand column just below half way.
