Auger stopped brand new Craftsman 1450 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-12-2019, 11:13 PM Thread Starter
I just purchased a brand new Craftsman 1450 Snowblower (27" 306cc model:190000). Like literally 5 hours ago.
After using it for about 10-15 minutes it the auger started to rattle and then died.
I checked the shear bolts obviously and all good.
Opened up the belt cover and belts are good.
However, I noticed 3 nuts sitting at the bottom.
I'm certain this isn't a quick fix so i'll be returning this tomorrow. I'm just hoping to learn from *** happened with this bs if you know what I mean.
Thanks in advance!
Harv Gill is offline
post #2 of 5 Old 02-13-2019, 11:33 AM
Likes (Given): 14
Likes (Received): 330
Sorry to hear of your problem. The fact there's bolts in the bottom sounds like something wasn't assembled correctly.
Hope they get it all right the 2d time.
HCBPH is offline
post #3 of 5 Old 02-13-2019, 11:53 AM
Thanks (Given): 45
Thanks (Received): 62
Likes (Given): 185
Likes (Received): 126
Maybe something in the auger clutch assembly came loose. You said the belts were good, can you tell if the clutch assembly was working properly?
Paul
1995 Toro 724, 1988 Toro 521
paulm12 is online now
post #4 of 5 Old 02-13-2019, 12:55 PM Thread Starter
Thanks for the replies guys.
I had another look and all I can tell is that the belt on the auger side is loose. Like I can pull it off with one finger. Not sure if its supposed to be that way.
When I press the auger control handle the clutch engages but the belt on auger side doesn't spin. I tried using my foot to push the clutch a bit more since the wire from the auger handle had some slack but it doesn't help. It actually starts to make a scratchy sound but still not engaging the belt.
Thanks again.
post #5 of 5 Old 02-13-2019, 08:01 PM Thread Starter
I had to drive a bit further to another Rona but I got a new one and I ran it for much longer and all seems good. Although the little clip on the chute control came off and I had to manually direct for the last 10 min.
I did look at the belt area and at rest the belt on the auger side is a bit loose I guess as it should be. I did notice that the clutch did go a bit further on this one. In any case, whatever broke on the other one probably didn't let the clutch engage.
Thanks.
Similar Threads
Craftsman 536.xxx - 4 snowblowers reviewed HCBPH Snowblower Reviews 22 01-07-2017 04:56 PM
Craftsman 247.88970 auger belt problem skins6983 Craftsman Snowblowers 13 12-16-2016 09:31 PM
Craftsman Trac Drive 5/24: Auger always stays engaged Foreverfalcon40 Craftsman Snowblowers 12 06-26-2016 10:18 PM
Craftsman 247.88790 Auger not spinning Technobuff Craftsman Snowblowers 19 01-25-2016 10:34 AM
Craftsman Snowblower Auger won't turn simonooch Snowblower Repairs and Maintenance Forum 1 02-01-2011 10:11 PM
