picked up free craftsman 26 briggs engine drive issue - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-15-2019, 12:10 AM Thread Starter
picked up free craftsman 26 with briggs engine sign said FREE runs but drive doesnt so i pushed it home flipped it up on bucket took off bottom plate drive disc was loaded with looked like dried rubber from rubber wheel but it looked ok cleaned off with gumout then looked around wiped all kind of dirt grease oil and everything was fine then i noticed belt cover was off there i found what seemed to be a idler wheel flopping around i found the spring to reatache it and the hole in the wheel bracket where the spring goes wore right through so a trip to the internet and its still available 6.00 so i then decided to try out the electric start and tripped a circuit breaker but it pulls over i allready have a 28 craftsman with a 9 hp techemsua with joystick chute and ez steer which i allready changed rubber wheel and belts and 1 bearing not bad for a machine from 2005 like they say take care of it and it takes care of you after i fix this hopefully we get some snow to try it out
sheddski is offline
post #2 of 2 Old 02-15-2019, 12:24 AM
SimplicitySolid22's Avatar
Thanks (Given): 56
Thanks (Received): 74
Likes (Received): 110
Nice Score!!!!!!!!!!!!!
SimplicitySolid22 is offline
Similar Threads
Got a free Craftsman - Electric Start sounds ROUGH WalkThisWhey Craftsman Snowblowers 11 08-11-2017 12:35 AM
Help with drive pulley spring on craftsman (MTD) snowblower codog11 Snowblower Repairs and Maintenance Forum 3 03-22-2015 08:32 AM
B&S V-Twin Engine Swap grupe Snowblower Repairs and Maintenance Forum 25 01-29-2014 10:55 AM
Craftsman 179cc 24" idle issue flybooey Snowblower Repairs and Maintenance Forum 26 11-20-2013 04:24 PM
Craftsman 5/23 drive and engine issues archangel Snowblower Repairs and Maintenance Forum 8 01-21-2012 04:15 PM
