Reverse = Slow and slower? UGH! - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-17-2019, 08:36 PM Thread Starter
Likes (Given): 9
Unhappy Reverse = Slow and slower? UGH!
Hey Guys :-)
I have a 2012 Craftsman 28 inch Snow Blower ( model no. 247.883950) and can't understand why the reverse is so darn slow! Is there any way to make this thing go any faster in reverse? It's really frustrating!!!!! UGH!
Thanks,
AdkGal
AdkGal is offline
post #2 of 14 Old 02-17-2019, 09:02 PM
Thanks (Given): 118
Thanks (Received): 271
Likes (Given): 354
Likes (Received): 618
There should be. The manually hopefully describes how to adjust the transmission gear-selector. Whatever happens when you put the gear selector to Reverse, you'd want to increase a bit.
Let's say going into Reverse pushes a shift-rod down towards the tractor frame (vs pulling it up more and more, for faster Forward speeds). You'd want to adjust the shift rod to make it a little longer, so it can be pushed further down towards the tractor frame.
Anything you adjust to one direction will have the opposite effect on the other direction. Speed up Reverse, and you'll slow all the Forward speeds slightly. Make sure you don't go too far. First gear Forward should still make the machine move forward. If it doesn't move at all, or goes backwards slightly, then you adjusted too far.
Thanks AdkGal thanked for this post
Likes AdkGal liked this post
post #3 of 14 Old 02-17-2019, 09:03 PM
Jackmels's Avatar
Thanks (Given): 95
Thanks (Received): 148
Likes (Given): 280
Likes (Received): 590
There is a Speed Adjustment. The Speed Selector has a cable connected to it. Follow the cable down to the bottom, and the adjustment is there by lengthening or shortening the Cable.
Jackmels is offline
post #4 of 14 Old 02-17-2019, 09:05 PM
tdipaul's Avatar
Thanks (Given): 71
Thanks (Received): 68
Likes (Given): 241
Likes (Received): 283
Does your driveway config allow for a 180 turn to minimize reversing moves?
1979 Toro 5/24 38040 (now a 6.5/24)
1983 Craftsman FF20 plow tractor
tdipaul is offline
post #5 of 14 Old 02-17-2019, 09:06 PM
aldfam4's Avatar
Thanks (Given): 199
Thanks (Received): 38
Likes (Given): 542
Likes (Received): 106
Originally Posted by AdkGal View Post
Hey Guys :-)
Thanks,
AdkGal
I have the same machine, I just put it in neutral and pull it backwards, works for me. I will make some adjustments next year as were outlined by Redoctobyr's post.
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #6 of 14 Old 02-17-2019, 11:31 PM
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
Slow is smooth and smooth is fast...
Dannoman is offline
post #7 of 14 Old 02-22-2019, 09:54 AM Thread Starter
Likes (Given): 9
Thanks Redoctobyr, That was exactly what I was looking for!
AdkGal :-)
AdkGal is offline
post #8 of 14 Old 02-22-2019, 10:03 AM Thread Starter
Likes (Given): 9
tdipaul.......
Yes, I can do 180's, but there are places where I can't and need to use reverse. I can't always pull the machine back because of hills and such.. it's just too heavy for me to pull it uphill. So, I need/want it to go faster in reverse. There is a lot of snow here in the Adirondacks, and a lot of area to snowblow. I'm just trying to get it done more quickly with a speedier reverse.
AdkGal :-)
AdkGal is offline
post #9 of 14 Old 02-22-2019, 10:46 AM
Homesteader's Avatar
Likes (Received): 33
You can get a larger drive pulley and belt. That will give you the reverse speed you want but decrease the toque, placing a higher load on your engine going over steep hill - minor load, but have a faster 1st gear as well.
There are always trade offs.
You can also adjust the neutral position back to increase reverse speed but you will reduce how fast you will go in drive gears.
I’ve used a rotary tool to cut out an additional notch in my control panel to give myself a higher forward speed for moving from driveway to driveway. You could do this for your reverse gear if you machine allows for the clearances.
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
post #10 of 14 Old 02-22-2019, 08:59 PM Thread Starter
Likes (Given): 9
Hey Homesteader :-)
This snow blower is CRAZY fast even in the 3rd gear (6 fwd available) Not sure I want to do the larger pulley and belt, thing, but will give it a go with the adjustments to obtain a faster reverse. But your post is definitely interesting and possibly a fix if this adjustment doesn't work.
Thanks!
AdkGal :-)
AdkGal is offline
Similar Threads
Ariens Deluxe 27 921012 really slow reverse johnnyh55 Ariens Snowblowers 12 12-14-2018 12:32 AM
HSS928 is really slow prune Honda Snowblowers 7 11-28-2018 11:22 PM
PowerShift reverse speed KVacek Toro Snowblowers 15 01-19-2018 02:03 PM
Ariens 8524 is too slow, can I make it move faster? nagelxj Ariens Snowblowers 11 12-31-2015 07:05 AM
slow forward Bill T Honda Snowblowers 7 02-14-2014 05:04 PM
