LinkBack | Thread Tools |
NEW SQUEAK in reverse...diagnosed... need part!
I've got a C950-52670 10hp (Tec) 32 inch trac drive monster...
I have been through the tracks and transmission several times since I bought it...the fellow I got it from did not maintain it..so it needed lube and several bolts/nuts etc replaced..
Seems like I can disassemble it (to a point) in my sleep..
anyway after the last 20cm dump of snow I had to blow the snow that I pushed to side of my 1/4 mile driveway over the berm that plowing creates... the berm is about 4 ft tall..place looks like a luge track..... so two trips up and back equally 1 mile in 2nd or 3rd gear.. that was almost 2 hours, then another hour cleaning up around various buildings.. in all about 3 hours hard work... and a tank of gas..
when I finished I noticed a NEW SQUEAK when reversing, not in forward..
when I opened up the belly pan I noticed the hex shaft was not running in a circle at the left side of the machine where it enters a bearing/bushing
#71 on the diagram (from service manual) part #1413 Bearing and retainer
its a 3 bolt style.. when I try to find it online I only find 2 bolt style bearings...anyone got a source for this part?
and...
how the heck do I remove that bearing?
thanks a million
and...
thanks a million
Sponsored Links | |||
Advertisement |
Well I got the shaft and the bearing out.. turns it not the bearing.. the shaft is BENT on the left side..at tha little gear I'd say about 5 degrees or so.. how I don't know.. I tried to straighten it out but no way.. so I need a new shaft.... where the heck do I get one?
Sent from my SM-G950W using Tapatalk
Part 89
Do you have the Murray part number???? Here is one on Amazon. There are more listed. Just Google the Murray number.
http://www.amazon.com/gp/product/B00...KIKX0DER&psc=1
GLuck, Jay
GLuck, Jay
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes |
Craftsman part 4062... I'll see if its the same as the Murray number....thanks
585855MA looks to be it...
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Tecumseh muffler heat shield part 36294 WANTED! | FearlessFront | Snowblowers and Snowblower Parts Wanted | 5 | 02-15-2018 03:33 PM |
PowerShift reverse speed | KVacek | Toro Snowblowers | 15 | 01-19-2018 03:03 PM |
Platinum 24 - Stuck in gear, no reverse, shift fork disengaged (Solved) | TheHolyCannoli | Ariens Snowblowers | 35 | 12-18-2016 09:38 AM |
How to find part #'s for Craftsman 88394 and add impeller kit? | LKS | General Snowblower Discussion | 0 | 10-02-2016 11:02 AM |
Compatilble snowblower auger part maker | ailleacht | Snowblower Repairs and Maintenance Forum | 4 | 04-20-2013 07:16 AM |
Posting Rules | |
