Drift breaker down - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-18-2019, 03:26 PM Thread Starter
Drift breaker down
I'm in need of some good parts or good guidance on where to go from here. It appears that I have some excessive wear on the shaft powering the driving member of the friction disk drive and it is allowing the driver to move around taking the pressure of the driven disk, anyone else run into this?
Sent from my SM-G900V using Tapatalk
T_Ruff is offline
post #2 of 3 Old 02-18-2019, 03:27 PM Thread Starter
Forgot the pictures
T_Ruff is offline
post #3 of 3 Old 02-19-2019, 11:42 AM
Thanks (Received): 141
Likes (Given): 14
Likes (Received): 329
Looks like one I used to have. There is a brass bushing on each side of the bracket that holds the shaft. IIRC it's comparable to the ones used on the axels. Pull the shaft and replace the bushings. Big thing to check though, the shaft in mine was cut from the wear with the worn bushings.
Hope that helps. Good luck
HCBPH is offline
Similar Threads
Craftsman Drift Breaker 536.882702 5289 Restoration 10 hp 32" 2nd Generation sock-feet Craftsman Snowblowers 183 12-02-2019 08:35 PM
Craftsman 536.906100 'Transitional' Drift Breaker turmlos Craftsman Snowblowers 14 09-12-2018 09:35 PM
Drift Breaker transmission help needed! spechacek82 Craftsman Snowblowers 1 11-25-2016 09:46 AM
Newbie NW Ohio, Sears Craftsman Drift Breaker dritbreaker New Member Introductions 22 10-06-2015 08:36 AM
big Craftsman Drift Breaker 10/32 broken friction disc casting pt2 greatwhitebuffalo Snowblower Repairs and Maintenance Forum 12 11-29-2014 05:06 PM
