High altitude jets? - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 03-18-2019, 12:33 PM Thread Starter
High altitude jets?
I am at 7800ft and my craftsman snowblower seems to run a tad rich. It sounds like it's not running just quite right at full throttle.
Does anyone know a document that has the right jet size?
Currently has a 184 jet, but I found a 207 jet online that states it is for high altitude. Is this the correct one ? I would think the number would be smaller for a smaller jet?
geekwithoutacause is offline
post #2 of 3 Old 03-18-2019, 01:14 PM
ST1100A's Avatar
Thanks (Given): 134
Thanks (Received): 115
Likes (Given): 245
Likes (Received): 197
A 207 is normally a "Richer" or "Bigger" jet, so that would be the wrong jet for higher altitude where you would have to go smaller or "Leaner". That would be on a Honda motor or an American made engine. A China motor or carb could be backwards or opposite.
ST1100A is offline
post #3 of 3 Old 03-18-2019, 05:23 PM
Likes (Received): 279
Your better off with it running a bit rich than end up to lean..... if it's an adjustable carb, just tweak it some and youll be fine. If it's starts to backfire and spit - your to lean.
Similar Threads
Re-jetting northeast Honda Snowblowers 810 01-10-2020 03:50 PM
Honda Snowblower High Chute Crank and Tall handlebar Kits alpinebobl Snowblowers and Snowblower Parts for Sale 7 01-21-2019 11:54 PM
Honda HS1132TA Engine Sputtering E350 Honda Snowblowers 8 03-18-2018 02:22 PM
Adjusting new carb with high and low speed jets theoldwizard1 Snowblower Repairs and Maintenance Forum 4 12-16-2017 01:02 PM
High altitude adjustment GoBlowSnow Snowblower Repairs and Maintenance Forum 6 10-05-2016 07:40 PM
