Model 247.887801 - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 20 Old 09-12-2019, 11:37 AM Thread Starter
Spraying the engine is a job for today if this monsoon were getting ends. Flow is great.
So far: I completely disassembled the carb and cleaned with top engine cleaner (the good stuff), then with carb cleaner and put it back together. The results were exactly the same. Then I bought a new carb and put it on to exactly the same results. Cleaning and 2 carbs doing exact same thing seems to eliminate the carb and send me back to checking for sucking air somewhere. I hate the idea of spraying ether/starting fluid around hot engines but I'll try it. It's a monsoon here today so I really haven't gone past loosening the gas cap, which didn't help. I suspect someone has been into this before me as the gas line was the good automotive kind instead of the cheap plastic ones that I'm sure must come with them. That line between the intake and the carb doesn't need to be clamp tight does it? I'm on my way to get a shutoff as I'm tired of draining the tank each time. I'll get extra gas line long enough to be able to hold up the cover with the tank to see if the low spot in the line are causing any problems, slight chance but I'll check. Primer line need clamps? Some of the gaskets on the original carb, stiffer and thicker with almost a slight bit of rubber around the openings which I don't think was sealer, seemed better quality than the new ones so I was a little confused if both were needed but ether should show a leak of any kind. after that I'm going to go throw it through the window of the guy that sold it to me. He told me it was 2, maybe 3 years old and he knew the guy that he got it from(He buys out estates and then resells) and partstree.com shows it as a 2011.
Hawg is offline
post #12 of 20 Old 09-12-2019, 11:52 AM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 325
Likes (Given): 3224
Likes (Received): 655
I would use carb spray or WD-40 to test for intake leaks.
The primer line does not need a clamp.
I doubt the low spot in the fuel line is causing your issue.
A fuel shut off is a GOOD idea on any gas engine machines.
If there is gasket sealer on the gaskets, make sure none of it is blocking any small holes which are air bleed or pulse holes needed for correct fuel metering.
The age discrepancy wouldn't bother me as long as the machine was maintained and probably had minimal use.
Good luck.
post #13 of 20 Old 09-12-2019, 12:02 PM
oneacer's Avatar
Thanks (Received): 136
Likes (Received): 487
Have you checked inside the tank for any obstructions of any kind?
Have you pulled the line itself to make sure it is free flowing? btw, good idea as mentioned, to put in an in-line shut off on any gas engine when you drain the tank.
I like the ether test as well.
BTW, for future info., I always put Stable and Seafoam into all my 5 gallon cans when I fill them .... I do however cut the Seafoam to 1/2 the recommended, 1/2 oz. per gallon, instead of the recommended 1 oz. per gallon, as I also add the Stable.
oneacer is online now
post #14 of 20 Old 09-12-2019, 12:10 PM Thread Starter
Grunt, I agree on the age and maintenance but he told me he used it once last spring and didn't need the choke on. I seriously can't believe that by the amount of gunk in the bowl. Gaskets came with the carb and are new with nothing on them. The breather hose from the intake to the carb is somewhat loose, that doesn't need to be clamped, right? I also think he knows it's been worked on before. I understand buyer beware but lying puts a little more suspicion to it. I have to admit it runs great at 3/4 choke.
Hawg is offline
post #15 of 20 Old 09-13-2019, 09:52 AM Thread Starter
I was told by a friend he puts a little motor oil on gaskets to help seal them. Is that right? Seems to the oil, being heat resistant would just stay slippery and not seal. Your thoughts?
Hawg is offline
post #16 of 20 Old 09-13-2019, 09:47 PM
Motor City's Avatar
Thanks (Received): 53
Do't put oil on the gaskets. They are made to use dry. It gets soggy with oil, it may tear or blow out. Where on earth did he hear this?
Ariens ST11528LE
Honda HS720
Motor City is offline
post #17 of 20 Old 09-13-2019, 10:18 PM
Thanks (Received): 93
Likes (Given): 38
Likes (Received): 247
What about the tar type tube, Form-a-gasket ? I have had good luck with that spread on a gasket.
RIT333 is online now
post #18 of 20 Old 09-13-2019, 11:54 PM Thread Starter
I bought a sheet of fiber gasket material. Now I need to find my exacto knife. I want this to be over. The original gaskets were much thicker than the cheap paper ones that came with the carb. Form a Gasket is what started this post. Most agree to leave them dry.
Hawg is offline
post #19 of 20 Old 09-16-2019, 09:05 PM
Motor City's Avatar
All you will do is make a mess to clean up next time the carb needs to come off. No need to use anything, install dry.
Ariens ST11528LE
Honda HS720
post #20 of 20 Old 09-16-2019, 09:06 PM
Motor City's Avatar
I hand cut gaskets all the time. Get a gasket punch set at Harbor Freight And an exacto, as you stated.
Ariens ST11528LE
Honda HS720
