Old Craftsman snowblower 3/20 - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 10-10-2019, 01:51 PM Thread Starter
Hello,
I'm trying to learn how to fix my small engines myself. I have an old Sears Craftsman snowblower 3/20 model # 536-884351. It doesn't start. I tried replacing the spark plug and putting new gas in, but it still won't start. I figured maybe it's the carburetor so, I have taken it apart somewhat. I still don't know how to get to the carburetor without taking the whole thing apart!
I did post this message before and I appreciate the advice, but I took off the top cover and still can't get to it.
So, do I have to remove the back piece also?
Varstrom is offline
post #2 of 3 Old 10-14-2019, 03:54 PM
hard to get to! I have one now working on it looking for sturdier flange bearing other than plastic. The manual says the adjustment is on carb bowl bottom but on mine it is a solid hex head bolt....
Dael V Escher is offline
post #3 of 3 Old 10-16-2019, 09:54 PM
Thanks (Given): 89
Thanks (Received): 178
Likes (Given): 69
Likes (Received): 409
Spray starting fluid in the carb, if it starts you have a carb problem, if it doesn't, you have a spark problem but check the spark first.
