What H.P. is my Craftsman 536884700 - Drift Breaker - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-20-2020, 12:09 PM Thread Starter
Trying to help a friend get a cylinder head for his Craftsman Drift Breaker. Model 536884700 no longer has parts or even a manual from partsdirect. He knows the motor is a Tecumseh but he cannot find the H.P. or model, etc. Supposedly (I've never seen the snowblower), there is a magneto block that sat close to the starter camshaft which in turn shot sparks to the sparkplug. Two small fragile screws held that block (magneto?) in place and they broke off. So he is looking for a few parts. He also was toying with the idea of going to Harbor Freight and just buying a new motor but doesn't even know the H.P. to look for. Any ideas?
Robert Conner is offline
post #2 of 9 Old 02-20-2020, 12:59 PM
Thanks (Given): 178
Likes (Given): 466
Likes (Received): 1045
Welcome to SBF.
It's a 32" blower so it more than likely has a 10 HP Tecumseh. I think, without looking, the the engine is an HMS 100 (?)
The engine number should be on the top of the engine cover, under the electric start plug.
Here is a new one...
https://www.ebay.com/i/184074165157?...SABEgJCQ_D_BwE
post #3 of 9 Old 02-20-2020, 01:07 PM
Thanks (Given): 178
Likes (Given): 466
More stuff...
https://www.ebay.com/sch/i.html?_fro...Desc=0&_sop=16
post #4 of 9 Old 02-20-2020, 01:12 PM Thread Starter
Thank you Joe. I sent that pic from ebay to him and he will need to confirm that this is his and it will fit. = Update: After sending that to him he also says his has a 1 inch output shaft and that the motor has a starter bolted on it also. So I will need to ask the person on ebay if his has that and will allow a starter to be bolted onto it.
post #5 of 9 Old 02-20-2020, 04:43 PM
Thanks (Given): 591
Thanks (Received): 772
Likes (Given): 4374
Likes (Received): 1743
to SBF Robert
Glad to hear it's getting saved rather than heading to the scrap heap. I have a 1032 DriftBreaker 536.918900 and they are a monster. Similar quality to the JDs and Ariens of that 70's, early 80's era
On his the model of the snowblower isn't as critical as the engine numbers are. On something that old it could be a replacement engine that's newer. On the Tech flat heads they never changed that much but it's nice to have the engine numbers when you're looking for parts. The numbers should be stamped into the top of the engine shroud. If it has electric start you might need to unscrew, remove the start button assembly on the top of the shroud as it covers the numbers.
Name:	111213 536.918900  from the front.jpg
ID:	164105   Click image for larger version
Name:	111213 536.918900  auger, impeller and drift breaker.jpg
ID:	164107   Click image for larger version
Name:	Engine ID Tecumseh Flathead.jpg
post #6 of 9 Old 02-20-2020, 09:33 PM
Thanks (Given): 178
Likes (Given): 466
You are.most welcome , Robert. Happy to be of help. I really hope he gets the old girl up and running.
post #7 of 9 Old 02-25-2020, 08:12 AM
Likes (Received): 345
The Craftsman 536.882700 blower came factory with a Tecumseh 10 HP HMS100 engine on it from the factory. Pretty solid engine, I've had a couple of them over the years and they do hold up and it's a very solid machine overall.
Biggest issue against the machine is the plastic bushings used on some of the blowers and even that's fixable using roller bearings.
HCBPH is offline
Likes Kiss4aFrog, 87powershiftx2 liked this post
post #8 of 9 Old 02-25-2020, 08:40 AM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Welcome to the SBF from Gettysburg!
2019 Ariens Compact 24...
penna stogey is offline
post #9 of 9 Old 02-25-2020, 11:01 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
if it's a warped head or one with a stripped plug thread any head from a like hp motor will work, it dose not have to be off a snow blower engine,
87powershiftx2 is offline
