Replacement engine - Snowblower Forum : Snow Blower Forums
post #1 of 30 Old 02-22-2020, 10:53 AM Thread Starter
Replacement engine
I have a 2005 Craftsman snowblower 1350 snow series 27" with a broken 1350 Briggs and Stratton Snow series engine. I cannot find an equivalent engine near that HP and torque with a 3/4" crankshaft. The closest I came to was a Pro Point engine from Princess Auto but the 1350 has a 3/4" crankshaft with a double pulley. The Pro Point has a 1" crankshaft. I cannot find pulleys to match. Does anyone have an idea where I can go from here? I have not bought the Pro Point engine yet.
chrisqc is offline
post #2 of 30 Old 02-22-2020, 11:48 AM
Thanks (Received): 96
Likes (Given): 701
Likes (Received): 244
the double pulley,meaning one on the crank and a 1/2 speed of the extended camshaft pulley makes it hard to re-power any machine with one,
it's been done in here ,with many threads on how to, please take note that it's a lot of work
https://www.snowblowerforum.com/foru...0engine%20swap
87powershiftx2 is offline
Likes ST1100A liked this post
post #3 of 30 Old 02-22-2020, 12:05 PM
Thanks (Given): 585
Thanks (Received): 764
Likes (Given): 4328
Likes (Received): 1727
Due to it being a Canadian Craftsman the model number of the blower might not help but can you please post it in case someone has some detailed info on it ?
You could always check with a machine shop to see what it would cost for someone to take the pulley and bore it out to 1" and cut a keyway into it.
Have you checked a couple of sources for pulleys and what it would cost you to get it up there ?
https://www.mcmaster.com/Pulleys
https://www.mscdirect.com/products/pulleys?rdrct=pulley
https://www.globalindustrial.com/c/m...ulleys-sheaves
https://www.northerntool.com/shop/to...cBiw&gclsrc=ds
post #4 of 30 Old 02-22-2020, 12:25 PM Thread Starter
I checked on those sights you sent but unfortunately they do not have what I will need. Is it possible and safe to have the crankshaft on the new motor machined down to 3/4"
chrisqc is offline
post #5 of 30 Old 02-22-2020, 12:50 PM
Thanks (Received): 14
Likes (Given): 35
I think you may have this type of pulley you are calling "double pulley?" You don't have to have it one piece, you can get two separate pulleys/sheaves. You can also get key stock so you don't need to have an integral key either. I think some manufacturers went to this design to speed assembly. If I was really critical I'd say they did it to make their product more difficult to service or swap engines with other manufacturers.
oneboltshort is offline
post #6 of 30 Old 02-22-2020, 12:52 PM
ST1100A's Avatar
Thanks (Given): 199
Thanks (Received): 125
Likes (Given): 402
Likes (Received): 265
One pulley spins the opposite direction of the other when it is a crankshaft and camshaft pulley.
ST1100A is offline
post #7 of 30 Old 02-22-2020, 01:03 PM
Thanks (Given): 167
Thanks (Received): 333
Likes (Given): 462
Likes (Received): 820
Do we know it's actually that type of engine, though? It was referred to just as a double pulley. That could mean 2 belts driving the auger, etc etc. I know Tecumseh made engines with 2 output shafts, did Briggs, in that time frame?
chrisqc, to avoid confusion, does your engine have 1 output shaft, or two? Some pics would help.
As to whether the crankshaft could be machined down, maybe. I mean, it can probably be done. But if you had to disassemble the engine, remove the crankshaft, and have it machined, I have to wonder if finding a "proper" replacement would be easier, cheaper, and more likely to be successful.
Thanks ST1100A thanked for this post
post #8 of 30 Old 02-22-2020, 01:08 PM
Likes (Given): 701
yes! the op has a double on a single shaft ,his issue is he can't find a 3/4 shaft only 1 inch that will work, plus he is looking for the same od pulleys
post #9 of 30 Old 02-22-2020, 01:28 PM
Thanks (Given): 585
Likes (Given): 4328
Sure. Just a bit of work taking a new engine apart and then buying the gasket kit to reassemble, IMHO.
Likes ST1100A, 87powershiftx2 liked this post
post #10 of 30 Old 02-22-2020, 06:26 PM Thread Starter
Yes that is what I have. And yes I agree with you on the builders thinking.
chrisqc is offline
