engine specifications for replacement harbor freight predator - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-10-2014, 03:42 PM Thread Starter
Hey guys im trying to get a replacement engine for my dads craftsman 6.5 Briggs 24" snoblower.its a 2005 model # 536.881651. The engine model # is 12e114 0268 E1. Im looking to replace it with the predator 6.5hp from harbor freight.Any idea if this is a direct fit and how does it perform. I cant find the briggs engine specifications anywhere shaft size etc. Thanks any help would be greatly appreciated.
bigdee4444 is offline
post #2 of 15 Old 02-10-2014, 03:48 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Pulleys are relatively cheap if you need them. The Predator has a 3/4 inch PTO if the old engine had 3/4 inch pto then the old belt pulley will most likely work. If not you can get replacement pulleys from Pheonix or Grainger ot TSC sometimes
GustoGuy is offline
post #3 of 15 Old 02-10-2014, 03:54 PM
I'm pretty sure its a direct swap.
scipper77 is offline
post #4 of 15 Old 02-10-2014, 04:13 PM Thread Starter
i just checked harbor freight they offer 3 different 6.5 hp predator engines. lol. Any idea which one.
post #5 of 15 Old 02-10-2014, 05:42 PM
Thanks (Received): 28
Likes (Received): 58
The predators are number for different series (updates or use in california etc) any will be fine.
In regards to your other post you dont need the specs online, just go measure it.
Take off the belts and engine pulley. measure the diameter of the crankshaft. measure from the center of the crankshaft to the bottom of the motor where it is bolted to the snowblower (crank height centerline), measure the bolt pattern for mounting base plate of the motor.
I just changed an overhead briggs like yours on a craftsman and this is what you need to do.
1-- original pulley should work fine but you will need a longer pulley center bolt (5/16 fine thread),
2-- the pulley needs to slide onto the crank but you need to put a spacer about 1/4 inch thick on the crank first to align the v-belts.
3-- Three of the four mounting studs will line up fine. the fourth--front left when standing at the operator position--will need to be elongated a little bit.
If I think of anything else I will let you know but I think that was it.
td5771 is offline
post #6 of 15 Old 02-10-2014, 05:59 PM
Thanks (Received): 148
Likes (Given): 215
Likes (Received): 305
I thought I saw a different set of drawing in a post here somewhere, but here is a page from the product manual avaolable at the HF web page.
dbert is offline
post #7 of 15 Old 02-10-2014, 06:05 PM
Likes (Given): 215
Screen shot too small to read.
6.5 HP (212cc) OHV Horizontal Shaft Gas Engine
Get the scaleable pdf. file from the above link or directly from here
http://manuals.harborfreight.com/man...9999/69730.pdf
dbert is offline
post #8 of 15 Old 02-10-2014, 06:10 PM
1 more thing. When you put the engine pulley back on the crankshaft does not reach the end of the pulley. There is still plenty of pulley on the crank but for stability when you put the bolt in you need to fill the gap at the beginning of the pulley between the bolt and pulley. I used a spacer but a short stack of washers is fine. It will be 5/16 id and 3/4 od.
td5771 is offline
post #9 of 15 Old 02-11-2014, 12:50 AM Thread Starter
appreciate everyones help. i ordered the 69730. Total with tax and shipping after coupon
$104 cant beat that. Hope its an easy swap and it runs good
post #10 of 15 Old 02-11-2014, 08:04 AM
You will be very happy. I know you will be surprised buy how much power that little motor really has.
