RPM range? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-13-2014, 08:31 PM Thread Starter
RPM range?
I have a 11.5hp /30" cut with the Briggs & Stratton motor. Im curious to know what the rpms should be at when at full throttle. Ive searched here, online, and the manual and come up short.
craftyman is offline
post #2 of 9 Old 02-13-2014, 08:48 PM
Most 4 cycle engines should be at 3600 RPM full throttle and around 1200 - 1750 at idle.
post #3 of 9 Old 02-13-2014, 08:52 PM Thread Starter
Is it adjusted through the carb or throttle lever?
post #4 of 9 Old 02-13-2014, 08:53 PM
3600 is standard. I think it's a safe assumption
scipper77 is offline
post #5 of 9 Old 02-13-2014, 08:54 PM
There should be an adjustment screw on the carb somewhere. Don't mess with the linkages.
post #6 of 9 Old 02-13-2014, 09:08 PM Thread Starter
Thanks everyone
post #7 of 9 Old 02-16-2014, 07:02 PM Thread Starter
So i tore into the snowblower last night. The carb has no adjustment screws ???? All i have are 2 rods that go to the throttle lever but they do not move when i move the throttle? Any ideas on how to adjust the rpm's. Im running on the low side and would like to bring it up to normal
post #8 of 9 Old 02-16-2014, 08:45 PM
Likes (Received): 42
Hard to say. You haven't indicated what you have for equipment, make and model. There is an adjustment for rpms somewhere, but it could be on the throttle linkage as opposed to the carburetor itself. Need to know what you have first. MH
motorhead64 is offline
post #9 of 9 Old 02-16-2014, 09:16 PM Thread Starter
Its a craftsman 11.5hp briggs and stratton. Im thinking the linkages are connected to the governer. But not sure how the rpms would be adjusted as the governer runs off internal mechanics on the crank shaft
