Restoration 536.884810 5hp/23" width Craftsman II Trac-Drive - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 03-03-2014, 04:59 PM Thread Starter
Thanks (Given): 15
Likes (Given): 14
Just completed my first snowblower restoration project!
Recently purchased a 536.884810 5hp/23" width Craftsman II Trac-Drive on Craigslist. It ran, but motor seemed weak and the Trac-Drive train was a bear to use. It seemed frozen and binding.
Today, following a piece-by-piece tear down, inspection, and restoration or replacement of every engine and drivetrain part, I am proud to say that the snowblower looks and runs like new.
I learned a lot working with this model. It proved to be more complex and in need of more obsolete parts than I ever would have imagined.
If I can help you with what I learned, let me know!
UPDATE: Kudos to stuart80112 for excellent discussions and documentation of working on his 536.884810 machine. Similar kudos go to PLZ523. To make searching easier, I have copied the following entry and links to TracDrive photos posted by stuart80112.
QUOTE:
>>Pictures show location of zerks and location of spacer washers during reassembly.
>>Photos:
>>https://goo.gl/photos/j5W2g7RJtbvL6TmD7
ALSO: Disassembly of TracDrive Photos:
http://redirect.viglink.com/?format=...REa0VoM3l5cVZ3
Last edited by Hankfard; 01-08-2017 at 05:07 PM. Reason: Added link to TracDrive photos from stuart80110
Hankfard is offline
post #2 of 26 Old 03-03-2014, 05:32 PM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
Welcome to the forum, you should have joined before you rebuilt it all. Then you could have done a rebuild thread.
Have you been so lucky as to have snow to try it on yet?
This last storm that predicted my area yesterday and today said we would have 12" plus....... turned out to be 1/16 of an inch for me.
This guy might need some of your expertise on the track drive.
Check out his thread and jump right in if you can help him out, https://www.snowblowerforum.com/forum...ck-drive.html?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #3 of 26 Old 03-03-2014, 09:01 PM
Thanks (Received): 143
Likes (Received): 297
Welcome, to another tread-head. There is something to be said about complex machines, then tend to make you look for more complex machines. Mine, is my "Ricky."
post #4 of 26 Old 03-04-2014, 09:49 AM
Likes (Received): 345
Welcome
Welcome to the forum. One suggestion is to watch those tracks. I've seen and heard they can rust onto the respective shafts and become hard or impossible to drive.
I've also read where some people drill into the hubs to add grease zerks to them and supposedly have had good luck with that.
Good to see another 'old girl' running like a 'young chick' - congrats.
HCBPH is online now
post #5 of 26 Old 03-04-2014, 03:57 PM Thread Starter
Thanks (Given): 15
Likes (Given): 14
Thanks Guys...
I agree that the Trac-Drive is the best and worst feature of this unit. The plastic hubs that secure the tracks to the 3/4" main drive axle are VERY prone to building up rust inside the hubs, as well as in the chain sprockets that drive the track wheels. That creates tremendous friction where you don't want it.
The rust in my hubs was so bad that the snowblower could not be budged forward or backward without power. That created excessive wear on the the friction disc and the hex shaft, so much so that the bronze hex shaft bearing was wallowed out and cracked, and the friction wheel rubber was toast.
The main drive shaft could not be removed from the unit without cutting it in half, since the chain sprockets in the trac-drive were "welded" to each end with rust. After cutting the axle shaft, I was finally able to salvage the sprockets following a day in 12-volt electrolysis with sodium carbonate. That is among the best rust removal techniques going. Brute force with a gear puller was only bending and ruining the sprockets!
I have not installed zerks on these track hubs yet, but I will very soon since pushing grease into them is a great way to keep water and rust out. I did already install a zerk on the friction drive plate input shaft to preserve the 2 new needle bearings. Also replaced the hex shaft bronze bushing with a ball-bearing equivalent from Ariens. A big shout out to "td5771" for "Fix to avoid big failure on Murray machines"; and to "archangel" and "Shryp" for the hex shaft bronze bushing replacement with a ball bearing. See "Craftsman 5-23 Track drive...PARTS N.L.I.S?"
Sure like the idea of stainless steel shafts to replace to steel versions so common to all these machines!! Would be very easy to make up on a lathe.- guess that will be my next shop investment. [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
This is a sweet little forum - Thank you!! [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
"Dancing Girl" -
Craftsman II: 5/23 Trac-Drive 536.884810
Engine: Sears 143794053 aka Tecumseh HS50-67291H
Hankfard is offline
Thanks SAVAGE420 thanked for this post
Likes SAVAGE420 liked this post
post #6 of 26 Old 03-22-2014, 02:08 AM
Nice work on the Trac Drive, I just picked up an 8/26" model with a bad engine.
930dreamer is offline
post #7 of 26 Old 03-22-2014, 03:11 AM Thread Starter
Thanks (Given): 15
Likes (Given): 14
Thumbs up
Enjoy the process! Let me know if I can give you any insight based on my experiences.
Hankfard is offline
post #8 of 26 Old 03-22-2014, 08:08 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Great job Hankfard!
My neighbor has this machine...i'm forwarding him this thread
('87 Toro 38150 826)
post #9 of 26 Old 04-25-2014, 10:07 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
Need more pictures :-(
post #10 of 26 Old 09-24-2014, 12:40 PM
X2!
Looks amazing, love to see more!
o.c.94 is offline
