1976 11hp 3 stage Craftsman. Need Info - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 05-22-2014, 11:03 AM Thread Starter
I have a model no 536.906010 thrower. I gave I gave it to a friend to restored it and then had a stroke and died. He repainted it, it looks and runs like new! I now have it back but not all the manual pages. He removed the two compression levers and cables used it engage the wheel drive. The machine runs perfectly but w/o drive control I believe it is dangerous for use in close areas. Does anyone have a copy of the manual? Sears/Craftsman does not. If I can see the parts drawing I will be able to reassemble or rebuild the drive control. Sid
SidKim is offline
post #2 of 9 Old 05-22-2014, 09:46 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4354
Likes (Received): 1736
Post a picture of it. I have a 1032 3 stage and if it's similar I can take pictures for you.
post #3 of 9 Old 05-22-2014, 10:00 PM
Thanks (Given): 588
Likes (Given): 4354
Your snow blower and mine were built for Sears by Noma. Murray acquired Noma when they went out of business and then Briggs (& Stratton) took over Murray when they went out of business. Briggs doesn't have any of the product info from Murray much less Noma.
Hopefully someone has a copy and sees your post.
post #4 of 9 Old 05-22-2014, 10:06 PM
Thanks (Given): 588
Likes (Given): 4354
Try this at sears parts direct. It's for a 1032 3 stage 536.882702
http://www.searspartsdirect.com/part...dMod=536882702
post #5 of 9 Old 05-23-2014, 08:37 AM
Likes (Given): 1880
Likes (Received): 661
hello skidkim, welcome to SBF, hcbph seems to be the most informed abot those old craftsman snowblowers so send him a pm if he doesn't respond to this post
post #6 of 9 Old 05-25-2014, 04:38 PM
Thanks (Given): 588
Likes (Given): 4354
So . . . how is it going ?? Was the info helpful, are you still lost, did you get a correct manual for your exact model . . waz up
post #7 of 9 Old 06-06-2014, 11:24 AM
Likes (Received): 345
Blower
Just checking in and saw this.
If you want pictures, here's one I did showing pretty much a full rebuild on a similar unit: Evaluating a used snowblower purchase and proceeding with a rebuild in Project How To's Forum
Send me an email and I can send you a pdf of a comparable machine. There's a wide range of years with different paint schemes that are virtually identical under the skin
Paul
HCBPH is offline
post #8 of 9 Old 06-13-2014, 11:32 AM Thread Starter
Thank you all for your reply's. I will try and put some pictures of the machine on this site. I could not get the pictures sent by HCBPH. All I got was add's. Naturally I had an error in the model number I sent before It is 536.906101. The shift handle structure is a different conf than the unit in the pictures sent by kiss4afrog. I may be able to get a friend to help me send the pictures of my blower. So far this month I have not needed the machine on Cape Cod. Will check Sears Parts now Sid
SidKim is offline
post #9 of 9 Old 06-16-2014, 10:07 PM
Shoot me an email. I have a book that may help you. Mine is dang near the exact as kiss4afrog. I have all kinds of pictures of the drive and motor swap. My 8hp tecumseh threw a rod, I have lots of parts to get rid of! I put on a 212cc predator and it runs like a champ and is strong! my email is [email protected]
awg1983 is offline
