Impeller Wanted -1501188E701 - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 06-03-2014, 08:12 PM Thread Starter
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Does any body have a used impeller for a Craftsman(Murray) model #536.881800, its an 8hp, 27 in. The part number is 1501188E701 or 1501188E701MA
Name:	8hp craftsman.jpg
ID:	16265   Click image for larger version
Ariens ST11528LE
Honda HS720
Motor City is offline
post #2 of 15 Old 06-04-2014, 09:00 AM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
Is yours that far gone that it can't be repaired?
Sid
Sid is offline
post #3 of 15 Old 06-04-2014, 09:28 AM Thread Starter
Motor City's Avatar
Sid
The person I bought it off of, bent the heck out of it. The base plate is bent as well as one of the fingers. And I don't have access to a press, to try and straighten it out.
Ariens ST11528LE
Honda HS720
post #4 of 15 Old 06-04-2014, 10:29 AM
a hammer and a welder welder would fix that, its totally fixable
post #5 of 15 Old 06-04-2014, 10:45 AM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3334
Likes (Received): 679
+1 on being repairable. A large hammer and some 4x4 wood blocks should straighten it out. Since it is bent, I would also make sure the correct shear pins were\are installed in the future. Checking the auger gear box teeth would also be advisable before NEXT winter.
Grunt is offline
post #6 of 15 Old 06-04-2014, 12:31 PM
those have a brass gear right?
post #7 of 15 Old 06-04-2014, 05:32 PM
Sid
Thanks (Given): 10
Likes (Given): 30
It looks repairable to me also. When you finish straightening it, try to balance it. You might be able to put it on one of those lawn mower blade ballancers. I use a couple of 1/4" ball bearings and one or two bronze bearing sleeves, and a 1/4" rod, or a long shank 1/4 " drill clamped in a vice. It takes some time, but it can be quite accurate.
Sid
Sid is offline
post #8 of 15 Old 06-04-2014, 06:10 PM Thread Starter
Motor City's Avatar
Here's a side view of how bent it is. I only have a Mapp gas torch. I may try tomorrow, to see if I can get it hot enough to bend back.
Ariens ST11528LE
Honda HS720
post #9 of 15 Old 06-05-2014, 09:12 AM
Sid
Thanks (Given): 10
Likes (Given): 30
Put it on a concrete floor, and you should be able to hit that high spot on the back plate of the impeller. Once it starts to flatten out, put some hard wood [oak,mahogany] under on ether side of the high spot to complete the job. It doesn't have to be perfect, but it should be very close. You will need a 3 or 4 pound hammer to do it easier.
Sid
Sid is offline
post #10 of 15 Old 06-05-2014, 10:19 AM
Sid
Thanks (Given): 10
Likes (Given): 30
Sorry, I did not read post #3. I just wrote more of the same.
Sid
Sid is offline
