Craftsman CL ad, opinion - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 10-15-2014, 10:32 AM Thread Starter
"Sears Craftsman Snow Blower
2 stage
22" path
4 speeds forward
1 speed reverse
5 HP
electric start & pull start
Runs Good
$200.00"
What can you tell me about this model, and is it worth the 200.00 posted?
Also, I was going to just use it this yr. before I found a larger one next spring. I have got a late start, and anything worth anything is either gone or priced too high.
I have a 23x60 level driveway, which in the past I have been able to clean using a single stage for most snowfalls. Hopefully this is an upgrade until I get a larger model next yr. Who knows, this might be a good one for those avg snowfalls, and get another one for the monster dumps.
The code is 9302 serial #5369318200 if that helps identify it.
Art
ID:	22641   Click image for larger version
aggriffin3 is offline
post #2 of 21 Old 10-15-2014, 07:45 PM Thread Starter
Ended up purchasing this one, even though it wasnt an Ariens. I felt like it was too good to pass up for this yrs snow. Maybe something larger next yr.
Might be a little small for the real heavy stuff at the end of the driveway, although the owner says it goes through that stuff too.
He had new belts on it, a new carb two yrs ago, and brand new skids.
Hardly any rust except for surface rust in the chute and on the edges of the auger box. Ran like a charm. Paid 160.00.
So if anybody can tell me more about this model based on S# I would appreciate it. It does need some pneumatic tires to complete it. Any ideas on the best place for those?
Art
post #3 of 21 Old 10-15-2014, 07:57 PM
I had a Toro 3521 with solid rubber tires and it worked just fine.
post #4 of 21 Old 10-15-2014, 08:27 PM
Thanks (Given): 173
Likes (Given): 460
Likes (Received): 1038
Thumbs up
I think you got a really fine snowblower for a fair price. It's a 'good looking machine and looks to be in nice condition. You'll probably keep it.
If you have a decent driveway you won't have a problem with those tires. If they are spinning you're going too fast for your blower to do it's job properly.
post #5 of 21 Old 10-15-2014, 10:49 PM
Thanks (Received): 143
Likes (Received): 297
You could always use some self tapping sheet metal screws to make those tires studded.
post #6 of 21 Old 10-15-2014, 10:53 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3346
Likes (Received): 679
Looks like someone took good care of it. This machine uses an actual gear box and not friction disc drive, that is a good feature. Here is a link to the parts list if you haven't already found it.
Sears Craftsman 22 In Snow Thrower Parts | Model 536918200 | SearsPartsDirect
post #7 of 21 Old 10-16-2014, 05:22 AM
Likes (Given): 1885
Likes (Received): 663
most of last winter I used my toro 521 with hard rubber tires and the only problem I had with traction was the one time it started sprinkling and the snow froze over. it was 8- 10 inches of wet heavy snow. with the ice I had no traction and only got the 826 cause it had chains on the tires but the 521 had no problems blowing the snow. enjoy your 5/22 craftsman and congrats
post #8 of 21 Old 10-16-2014, 12:26 PM
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
That looks nice for the money . Go slow and keep the old tires .. Good luck . and nice price .
eyeboltman
Eyeboltman is offline
post #9 of 21 Old 10-16-2014, 12:37 PM Thread Starter
Thanks, I hope it handles the heavy stuff to the point I want it to. I was debating the whole time as I was looking at it. Should I buy a 5HP which was in really good shape with new belts, skid plates and carb and ran like a gem, or ignore it and wait on a more expensive larger machine that I wasnt sure about?
I figure, I will be on the lookout without the pressure to buy a larger machine, probably an Ariens in the coming spring.
I have thought of restoring this next yr. and using it as a sidewalk and low snowfall machine.
Thanks for the comments and compliments
Art
post #10 of 21 Old 10-16-2014, 01:02 PM
Thanks (Given): 173
Likes (Given): 460
I'm tellin' ya, Art. That snowblower is going to probably surprise you. You put a couple drift cutters on it and it'll do you fine. It's a good machine. Most important thing is to let it do the work and don't force it. You'll get the hang of it in no time a'tall.
