Eager-1 - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 11-13-2014, 04:49 PM Thread Starter
Eager-1
So I got this snowblower today. The original owner said it is a 1974 model. It is a 536.905903 model. It is a 5 hp with 20" clearing width. In all it looks pretty clean!
Anyway, they were going to give it away for free. I gave them $20.00.
They said it started every year except this year. I got it home, gave it a few pulls, and could smell varnish immediately.
I took apart the carb, and the gas inside was green. Yuck. It needed a new bowl gasket, so I purchased a new kit.
I didn't do a good job of removing the carb and remembering where everything goes, but i've done this a few times, so I'm not too concerned.
I do have one question that I am hoping someone can answer. In the one pic of the carb, you will see a small hose. It is not the gasoline intake hose. I'm not sure what it is, or what purpose it serves. I'm wondering if this hooks up to the primer bulb somehow?
If anyone can assist me here, I would appreciate it!
ID:	24953   Click image for larger version
ID:	24961   Click image for larger version
ID:	24969   Click image for larger version
ID:	24977   Click image for larger version
Relli1130 is offline
post #2 of 15 Old 11-13-2014, 05:13 PM
Thanks (Given): 178
Thanks (Received): 310
Likes (Given): 472
Likes (Received): 1053
Thumbs up
Yessir. That there is the primer hose. Looks like you're going to need a new one.
That's a really nice looking machine you've got.
post #3 of 15 Old 11-13-2014, 05:20 PM
Thanks (Received): 127
Likes (Given): 43
Likes (Received): 907
Reason why I take lots of pictures when I disassemble. Memory kinda fades as we get older.
Coby7 is online now
post #4 of 15 Old 11-13-2014, 05:24 PM Thread Starter
thanks! much appreciated. where exactly does the primer hose connect?
post #5 of 15 Old 11-13-2014, 07:26 PM
Thanks (Given): 178
Likes (Given): 472
It connects from the primer bulb to where it's shown in this pic on the carb.
post #6 of 15 Old 11-13-2014, 07:48 PM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3371
Likes (Received): 683
Did you remove a sheet metal cover (heat box) to access the carb? If yes, the primer bulb is on that cover. If no, you should ask the seller if they still have the cover.
post #7 of 15 Old 11-13-2014, 08:50 PM Thread Starter
Thank You ...that's what I thought, but needed to make sure.
post #8 of 15 Old 11-13-2014, 08:52 PM Thread Starter
yes I did remove the sheet metal cover. I think I know what to do now.
I'm thinking of doing an impeller mod on this unit. Further research shows that this is likely a 3.5 hp, not a 5 hp as I originally thought. So I'm thinking an impeller kit might be a good idea. There is about a 1/4" gap or so between the impeller and housing. Thoughts?
post #9 of 15 Old 11-13-2014, 09:14 PM
Likes (Received): 82
The impeller kit will help with throwing distance but it really shines when you blow wet and slushy snow and try not have the engine lugging with the heavy snow. Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #10 of 15 Old 11-13-2014, 10:06 PM
Likes (Given): 1891
Likes (Received): 670
I think that's a single stage, no impeller just the auger
