Old Craftsman C944 52750 parts - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 11-17-2014, 06:55 PM Thread Starter
Just bought this machine and in the ad it stated that the machine "chews" belts. We thought it was a simple fix and decided to risk the $50. Went to pick it up and had them start it. Started first pull and ran like a charm. The gentleman told us that he replaced a belt and didn't get the right size. Being a true redneck, he jimmy-ed it so it would work. So it doesn't chew the belts as his wife put in the ad. Even better, right? My problem is that I can't find any manuals or info anywhere that tells me what the proper belt part number is or even what size it is. Can anyone help?
Shelmac is offline
post #2 of 18 Old 11-17-2014, 07:44 PM
Thanks (Given): 585
Thanks (Received): 765
Likes (Given): 4334
Likes (Received): 1727
Welcome to the forum Shelmac
Might help if you posted up a picture of the machine. Does it say made in Canada by that model number ??
post #3 of 18 Old 11-17-2014, 09:29 PM Thread Starter
This is the picture that accompanied the ad. I could get different angles tomorrow if you need to see something in particular.
I'm fairly certain (without looking) that it was made in Canada. I have read on different sites that I was most likely manufactured by Noma Canadiana, but was unable to find any information on their site.
Shelmac is offline
post #4 of 18 Old 11-17-2014, 09:33 PM
HJames's Avatar
Likes (Received): 11
That's a good looking older blower with a much newer engine. The engine alone should be worth your $50
HJames is offline
post #5 of 18 Old 11-17-2014, 09:37 PM Thread Starter
That was kinda our thoughts too! lol It would be even nicer if we could find the parts to make it run properly.
Shelmac is offline
post #6 of 18 Old 11-17-2014, 09:39 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Well, parts.sears.ca, isn't as friendly, as it is down here. Down here, we can look up exploded diagrams and parts lists and numbers.
Hopefully someone from your neck of the woods will be able to chime in to give you a link to find the info for your machine. And I looked through parts tree, and did not come up with anything for murray or MTD, two known manufactures of craftsman. So I referenced the 944 portion of your model number and it came back to a Husqvarna....?
Here's the link:
Craftsman OEM List | VintageMachinery.org
But there was nothing on parts tree, that was helpful.
post #7 of 18 Old 11-17-2014, 09:43 PM
db9938's Avatar
Forgive me, but that is a replacement engine. You may want to make sure that the pulley's are aligned. That could explain why it is eating them.
And my first impression, is that it resembles an Ariens.
post #8 of 18 Old 11-17-2014, 09:47 PM Thread Starter
I found that out quickly. It's like my machine is the red headed step child that they want to forget! Can't even find a mention on their site. lol
I will just keep hanging around until something shows up. lol
Shelmac is offline
post #9 of 18 Old 11-17-2014, 09:50 PM
The original belt might not even fit now that he changed the engine. Some engines use different heights on the crankshaft so the engine pulley could be sitting an inch higher or lower than it originally did. He could have changed the pulley size as well. So getting the original belt might be of no use to you. Just get one that fits and works and take note of its size.
post #10 of 18 Old 11-17-2014, 09:51 PM Thread Starter
[QUOTE=db9938;308561]Forgive me, but that is a replacement engine. You may want to make sure that the pulley's are aligned. That could explain why it is eating them. QUOTE]
I will take a closer look at the engine tomorrow.
Shelmac is offline
