Need help with model # id - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 08-25-2013, 12:59 PM Thread Starter
Albow's Avatar
The sticker with model # is missing it is a Craftsman winterized engine 2 stage 22" power propelled w/ a 5 hp Tecumseh 143 717092 this is old pre 1983? i have more photos in my albums.
ID:	2081   Click image for larger version
ID:	2089   Click image for larger version
ID:	2097   Click image for larger version
Albow is offline
post #2 of 6 Old 08-26-2013, 11:21 AM
td5771's Avatar
Thanks (Received): 28
Likes (Received): 58
hey albow, i sold a blower identicle to that one. you model number should be 536.918700, I kept the original manual
I believe restoration men forum has the manual online.
td5771 is offline
post #3 of 6 Old 09-03-2013, 10:38 AM Thread Starter
Albow's Avatar
Thanks i will check that out.
Albow is offline
post #4 of 6 Old 09-11-2013, 12:41 PM Thread Starter
Albow's Avatar
found out part #54499 for a belt cover but can't find anything out there. anyone know any place i could get one or one that would work? model # 536.918700 thanks
Albow is offline
post #5 of 6 Old 09-11-2013, 11:20 PM
Simplicity Solid 22's Avatar
post #6 of 6 Old 12-06-2013, 02:06 PM
Likes (Received): 345
Belt cover
Sorry, didn't see this earlier. Any belt cover from a 536-918100, 536.918200, 536.918700 (whether red and white or gray and black, 4 or 5 hp) will fit. Some are white, while others are black but are both shaped the same. I've bought a couple of junk machines in the past just for parts, including the belt cover.
You have the metal bushings on the auger and axels (due to the clamshells), that's the good ones. The bushings are still available but not the clamshells. About the only thing to watch is insure the auger rakes are loose on the auger shaft and not rusted on. I also like to get an electric starter and swap out the hard tires for pneumatics, which works very well.
HCBPH is offline
